FreeCAD as pre-post procesor for MBDyn
josegegas
Re: FreeCAD as pre-post procesor for MBDyn
Postby josegegas » Wed Nov 20, 2019 6:58 am
Yes, you are right, I think I need a bit more planning and less coding haha. Great advice, thanks!
HarryvL
Postby HarryvL » Wed Nov 20, 2019 9:14 am
josegegas wrote:
Wed Nov 20, 2019 5:04 am
Hi. Every time I make a change to the code, to test if it works as intended, I have to close FreeCAD and open it again, so that it "loads" the module with the changes... This is making me loose too much time. Is there a way to avoid this? Like forcing FreeCAD to load the module without closing it and opening again? I've tested to go from one workbench to another, but it seems FreeCAD loads all only once. How do you guys work?
Try reload(). See here: https://forum.freecadweb.org/viewtopic. ... lit=reload
josegegas
Postby josegegas » Wed Nov 20, 2019 12:08 pm
Another quick question. Is there any method that gets executed when the user clicks (single click) on a given object in the tree view? What I want to achieve: When the user clicks on an object, some other objects in the 3D scene get highlighted. Is this possible?
vocx
Postby vocx » Wed Nov 20, 2019 6:12 pm
I think what you want sounds like is possible but only in C++. That's basically what realthunder did in 0.19. Now when you hover over an object in the tree view, the corresponding element is highlighted in the 3D view.
Maybe there is an interface to override this behavior, but I wouldn't know for certain, you'd have to ask realthunder.
microelly2
Postby microelly2 » Wed Nov 20, 2019 8:47 pm
selection observer can handle selections
class SelObserver:
    def addSelection(self,doc,obj,sub,pnt):
        print ("Selection added",obj)
s =SelObserver()
FreeCADGui.Selection.addObserver(s)                       # install the function mode resident
#FreeCADGui.Selection.removeObserver(s)                   # Uninstall the resident function
microelly2
Postby microelly2 » Wed Nov 20, 2019 8:53 pm
here an example how I use reload for fast development. I use some naming convention and reloads the implementation file for each call
class FreeCadNodeBase(NodeBase):
    '''common methods for FreeCAD integration'''
    def __init__(self, name="FreeCADNode",**kvargs):
        super(FreeCadNodeBase, self).__init__(name)
        self._debug = False
        self._preview=False
    @timer
    def compute(self, *args, **kwargs):
        if self._debug:
            say("debug on for ",self)
        import nodeeditor.dev
        reload (nodeeditor.dev)
        a=eval("nodeeditor.dev.run_{}(self)".format(self.__class__.__name__))
        if self._debug: say("Done:",self)
        if self._preview:
            say("create preview")
            self.preview()
The class definition - here I only define the interface (parameters)
class FreeCAD_Blinker(FreeCadNodeBase):
    blinker sender
    def __init__(self, name="baked",**kvargs):
        super(self.__class__, self).__init__(name)
        self.inExec = self.createInputPin(DEFAULT_IN_EXEC_NAME, 'ExecPin', None, self.compute)
        self.outExec = self.createOutputPin(DEFAULT_OUT_EXEC_NAME, 'ExecPin')
        self.signal=self.createInputPin('signalName', 'StringPin', 'blink')
        self.data=self.createInputPin('signalMessage', 'StringPin')
        self.d3=self.createInputPin('signalObject', 'FCobjPin')
        self.d3=self.createInputPin('sleep', 'FloatPin')
and the compute fucntion in noteeditor/dev.py
def run_FreeCAD_Blinker(self):
louisgag
Postby louisgag » Thu Feb 06, 2020 2:53 pm
Hi José and everyone,
I read this whole thread and found some quite interesting discussions.
I've been involved with the development of MBDyn and was responsible for the team's participation in GSoC.
We do have another MBDyn pre/postprocessor addon for FreeCAD, but it needs improvement.
Because of that, it would be nice if you could release the code, even if it is not production-ready, so that we and others can build on it. (We are planning on participating in GSoC again this year)
I agree with your mention that MBDyn would be suitable as an alternative to animate the currently available assembly options.
To do so, what you want is to build a fully constrained MBDyn model using only static nodes.
Send me an email if you want to discuss this further and I'll get you in touch with the main developer of pre- and post-processing solutions for MBDyn.
Kind regards,
-Louis
Postby Kunda1 » Thu Feb 06, 2020 3:15 pm
josegegas wrote::point_up_2:
louisgag
Postby louisgag » Fri Feb 07, 2020 9:07 am
You're suggesting I write a private message? I already tried two weeks ago, but it just stayed forever in my outbox... maybe because I'm new to the forum?
microelly2
Postby microelly2 » Fri Feb 07, 2020 10:05 am
No, the receiver died not read the mail yet.
