Install multiple versions of freecad ubuntu
Mongrel_Shark
Postby Mongrel_Shark » Sun Sep 08, 2019 11:40 pm
I'm setting up a new pc. Its a work from home computer which has a sibling at work. The work one has Versions 0.16, 0.18.1 and daily0.19 installed. I got help on forum about this last time, but can't find my old post. Sorry for duplicating. I did google and forum search a lot before creating this post.(I haven't actually used daily or legacy in some time at work, after today I am suspecting updates may have broken my installs. Will be in office tomorow and can confirm.)
Trying to replicate and getting some issues. I got the stable and daily ppa's installed. but....
Installed stable first. It stopped working after I installed daily. I then re-installed stable, now I have both. but....
Daily is v0.18. Stable is 0.18.1. I did update and dist-upgrade. no change.
Daily:
OS: Ubuntu 16.04.6 LTS
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.12
Stable:
Version: 0.18.1.
Facepalm. After reading above I see my daily is a later version, its just the splash screen not up to date. Although I really want v0.19 for the Tech Draw updates??
I have 2 icons on my launcher, and can identify daily by hovering mouse over launcher icon for tooltip. So its mostly working, just not the version of daily I want
Moving on to my legacy install. I got the legacy ppa installed.
I can see its updating
Hit:9 http://ppa.launchpad.net/freecad-maintainers/freecad-legacy/ubuntu xenial InRelease
but when I try to install
sudo apt-get install freecad-legacy
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package freecad-legacy
Mongrel_Shark
Re: Install multiple versions of freecad ubuntu
Postby Mongrel_Shark » Mon Sep 09, 2019 12:06 am
update.
I saw this thread https://forum.freecadweb.org/viewtopic.php?t=27992
Which suggested I may have better luck if I uninstalled my other versions. Did an apt remove on stable and daily, and an auto remove after reboot to clear out the dependencys.
No joy with the legacy build.
mongrel@CADboss:~$ sudo apt update
Hit:1 http://au.archive.ubuntu.com/ubuntu xenial InRelease
Hit:2 http://au.archive.ubuntu.com/ubuntu xenial-updates InRelease
Hit:3 http://au.archive.ubuntu.com/ubuntu xenial-backports InRelease
Ign:4 http://linux.dropbox.com/ubuntu xenial InRelease
Hit:5 http://ppa.launchpad.net/freecad-maintainers/freecad-legacy/ubuntu xenial InRelease
Hit:6 http://linux.dropbox.com/ubuntu xenial Release
Get:8 http://security.ubuntu.com/ubuntu xenial-security InRelease [109 kB]
Fetched 109 kB in 1s (59.3 kB/s)
All packages are up to date.
mongrel@CADboss:~$ sudo apt install freecad-legacy
vocx
Postby vocx » Mon Sep 09, 2019 1:03 am
First of all, your Ubuntu version is too old. Although 16.04 is a long term release, in free software development terms, it is quite old.
If my memory doesn't fail, there are various threads that mention that the daily builds, that is, the 0.19 version, isn't available for that Ubuntu version because of some old libraries that exist in that system, Qt in particular, I think. In this case, you may have more luck using the AppImages instead of getting the packages from repositories.
As for the legacy repository, you can explore it here https://launchpad.net/~freecad-maintain ... cad-legacy
You can clearly see that the package is named freecad-0.16, not freecad-legacy. This is something that you need to pay attention to. Sometimes the repository and the package name are different.
For the PPA stable version, the package is named freecad, and it should supersede the package provided by the Ubuntu universe repository. For the daily, the package is named freecad-daily.
I don't know why you need this, but I think you are going to complicate your life trying to simultaneously install very old and very new packages.
triplus
Postby triplus » Wed Sep 11, 2019 10:50 am
FreeCAD 0.16 and FreeCAD 0.18 packages should be available from the PPAs on Ubuntu 16.04. Daily PPA doesn't get updated anymore (Ubuntu 16.04), but you can use the AppImage instead:
https://forum.freecadweb.org/viewtopic.php?f=4&t=39148
