Solidworks to FreeCAD Sketch questions
michav
Postby michav » Mon Sep 09, 2019 7:38 am
Hello Freecad forum,
Some questions regarding sketching
1. how to automatically mate a reference line to the midpoint of a sketch line
2. automatic constraints not working properly (its checked in my options but my lines are not automatically snapping to midpoints)
3. how to display sketch's and planes from one body, if im working on another body
4. if I am working on sketch B, how to snap to points in sketch A? is there a way to do this without the use of shapebinder?
Thanks!!
HarryGeier
Re: Solidworks to FreeCAD Sketch questions
Postby HarryGeier » Mon Sep 09, 2019 9:41 am
Thanks!!
#1 not yet possible, i think i was reading that this is a solver limitation
#2 same..
#3.You can see them , as long as they and the body are visible. Not for construction lines which are only visible in actual sketcher context
#4. When in the same body you use external geometry. Outside the body you use shapebinders or carbon copy.
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
kisolre
Postby kisolre » Mon Sep 09, 2019 9:54 am
#1 easiest way add point, create symmetry of edge vertices around that point. This will put it in the middle.
Postby chrisb » Mon Sep 09, 2019 12:32 pm
I am not familiar with the Solidworks notions, so you may need to explain better what you have done.
You are talking about snapping and sketches. These two don't go together. Snapping is used in Draft workbench and sketches in, well, Sketcher workbench.
If we are talking about Sketcher:
#3: While editing the sketch you can switch to the Model tab and change the visibility in the tree view.
openBrain
Postby openBrain » Mon Sep 09, 2019 1:41 pm
No real automatic way. Midpoints are not supported. The best way is as explained by @kisolre to add an extra point and constrain it to be symmetric between the 2 line endpoints. You can do that by just selecting the line + the extra point and clicking on symmetry constrain.
In case it may help, I attach (very) basic macro that will add midpoint in this way to all selected lines on a sketch. You can bind the macro with an icon and a keyboard shortcut if you use it very often.
Auto-constraining works correctly in the extent of the supported constraints. :D
Basically just make them visible in the tree view. ;)
The other way is to use Sketcher CarbonCopy (as Harry told). Each way has its pros & cons. :)
In SolidWorks, when your mouse pointer is close to a line midpoint, a "handle" appears there and you can use it as a snapping point to eg. start or end a line.
Don't totally agree with that. Mainly when using auto-constraining, there is some snapping effect (in the general meaning of the word). Say when you start a line, if you're close enough to an endpoint, it will add coincidence. Close enough to an edge it will add a point-on-line. Etc. ;)
AddCenterPoint.FCMacro
(1.05 KiB) Downloaded 6 times
Postby chrisb » Mon Sep 09, 2019 1:48 pm
Ok, so we talk in fact about Sketcher here. Just to mention it: Snapping to midpoint exists in Draft WB.
Sad to say, but using autoconstraints is to a certain extent a property of the sketch. If you have autoconstraints disabled when you first create the sketch, then it stays in that mode. There is already a discussion about this, perhaps even a tracker issue.
You can always switch it off and on again. That should enable the autoconstraints independently from previous states.
