Sketcher bug, says is fully constrained when it is not
bejant
Re: Sketcher bug, says is fully constrained when it is not
Postby bejant » Tue Sep 10, 2019 9:44 pm
freecc wrote:
Tue Sep 10, 2019 4:52 pm
move the vertical lines back and forth a little bit as you wish, then apply a 8mm horizontal constraint to the horizontal line. Now drag the horizontal line up and down with one of the vertical lines. The horizontal constraint disappears.
Thanks - I can reproduce this too (only occasionally) and for me the 8 mm Horizontal Distance Constraint doesn't only disappear - it gets deleted.
After dragging the vertical line segments and then applying the 8 mm Horizontal Distance Constraint the Solver correctly reports that I have 1 DOF remaining. If drag one of the vertical line segments (I used the right one), the Solver incorrectly Fully Constrains the Sketch. Now, while sometimes after dragging a bit more, the Solver correctly reverted to Under-constrained with 1 DOF.
It sure is a weird bug...
freecc
Postby freecc » Tue Sep 10, 2019 11:09 pm
another scenario that I get when moving the vertical lines is that the horizontal constraint gets deleted but the DOF remains at 1 when it should be 2. After some more moving up and down with the vertical lines it becomes 2 DOF which is correct.
bejant
Postby bejant » Wed Sep 11, 2019 3:02 pm
Notes added to existing tickets:
issue #3791 and issue #4032
openBrain
Postby openBrain » Wed Sep 11, 2019 4:05 pm
As said, I think that issue #4032 has the same root cause as issue #3976, i.e. edges that are tangent by design and not by constraint. ;)
bejant
Postby bejant » Wed Sep 11, 2019 9:57 pm
I was thinking here there initially is no tangency. The vertical edges aren't tangent to the arc until Tangency Constraints are applied or until the 8 mm Horizontal Distance Constraint is added to the horizontal line segment. Am I missing something?
openBrain
Postby openBrain » Thu Sep 12, 2019 9:43 am
No that's it. 8mm is a special value that makes arc and lines tangent indirectly without having tangent constraints applied. This case seems to be wrongly handled by the solver. ;)
