dialog box will not show
mfasano
Postby mfasano » Wed Sep 11, 2019 12:05 am
I am trying to create a script where it opens a dialog box for user input. I used Qt creator to make a UI file and pyside2-uic to make a python file for the dialog box. When I run it, the dialog box does not show.
Thanks.
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
# -*- coding: utf-8 -*-
# Form implementation generated from reading ui file 'init_val_prob.ui',
# licensing of 'init_val_prob.ui' applies.
# Created: Wed Aug 14 12:55:13 2019
#      by: pyside2-uic  running on PySide2 5.13.0
# WARNING! All changes made in this file will be lost!
from PySide2 import QtCore, QtGui, QtWidgets
import FreeCADGui as Gui
import FreeCAD as App
# from init_val_prob_dia import Ui_init_val_prob_dialog
class Ui_init_val_prob_dialog(object):
    def setupUi(self, init_val_prob_dialog):
        init_val_prob_dialog.setObjectName("init_val_prob_dialog")
        init_val_prob_dialog.resize(400, 300)
        self.buttonBox = QtWidgets.QDialogButtonBox(init_val_prob_dialog)
        self.buttonBox.setGeometry(QtCore.QRect(215, 240, 156, 32))
        self.buttonBox.setOrientation(QtCore.Qt.Horizontal)
        self.buttonBox.setStandardButtons(QtWidgets.QDialogButtonBox.Cancel|QtWidgets.QDialogButtonBox.Ok)
        self.buttonBox.setObjectName("buttonBox")
        self.int_time_txt = QtWidgets.QLineEdit(init_val_prob_dialog)
        self.int_time_txt.setGeometry(QtCore.QRect(30, 45, 113, 20))
        self.int_time_txt.setText("")
        self.int_time_txt.setObjectName("int_time_txt")
        self.init_time_lab = QtWidgets.QLabel(init_val_prob_dialog)
        self.init_time_lab.setGeometry(QtCore.QRect(35, 30, 47, 13))
        self.init_time_lab.setObjectName("init_time_lab")
        self.final_time_txt = QtWidgets.QLineEdit(init_val_prob_dialog)
        self.final_time_txt.setGeometry(QtCore.QRect(30, 95, 113, 20))
        self.final_time_txt.setText("")
        self.final_time_txt.setObjectName("final_time_txt")
        self.final_time_lab = QtWidgets.QLabel(init_val_prob_dialog)
        self.final_time_lab.setGeometry(QtCore.QRect(35, 80, 47, 13))
        self.final_time_lab.setObjectName("final_time_lab")
        self.step_time_txt = QtWidgets.QLineEdit(init_val_prob_dialog)
        self.step_time_txt.setGeometry(QtCore.QRect(30, 145, 113, 20))
        self.step_time_txt.setText("")
        self.step_time_txt.setObjectName("step_time_txt")
        self.step_time_lab = QtWidgets.QLabel(init_val_prob_dialog)
        self.step_time_lab.setGeometry(QtCore.QRect(35, 130, 47, 13))
        self.step_time_lab.setObjectName("step_time_lab")
        self.tolerance_lab = QtWidgets.QLabel(init_val_prob_dialog)
        self.tolerance_lab.setGeometry(QtCore.QRect(35, 230, 47, 13))
        self.tolerance_lab.setObjectName("tolerance_lab")
        self.tolerance_txt = QtWidgets.QLineEdit(init_val_prob_dialog)
        self.tolerance_txt.setGeometry(QtCore.QRect(30, 245, 113, 20))
        self.tolerance_txt.setText("")
        self.tolerance_txt.setObjectName("tolerance_txt")
        self.max_iter_lab = QtWidgets.QLabel(init_val_prob_dialog)
        self.max_iter_lab.setGeometry(QtCore.QRect(35, 180, 70, 13))
        self.max_iter_lab.setObjectName("max_iter_lab")
        self.max_iter_txt = QtWidgets.QLineEdit(init_val_prob_dialog)
        self.max_iter_txt.setGeometry(QtCore.QRect(30, 195, 113, 20))
        self.max_iter_txt.setText("")
        self.max_iter_txt.setObjectName("max_iter_txt")
        self.retranslateUi(init_val_prob_dialog)
        QtCore.QObject.connect(self.buttonBox, QtCore.SIGNAL("accepted()"), init_val_prob_dialog.accept)
        QtCore.QObject.connect(self.buttonBox, QtCore.SIGNAL("rejected()"), init_val_prob_dialog.reject)
        QtCore.QMetaObject.connectSlotsByName(init_val_prob_dialog)
    def retranslateUi(self, init_val_prob_dialog):
        init_val_prob_dialog.setWindowTitle(QtWidgets.QApplication.translate("init_val_prob_dialog", "initial value problem", None, -1))
        self.buttonBox.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "button box (OK cancel)", None, -1))
        self.int_time_txt.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "initial time text", None, -1))
        self.init_time_lab.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "initial time label", None, -1))
        self.init_time_lab.setText(QtWidgets.QApplication.translate("init_val_prob_dialog", "initial time", None, -1))
        self.final_time_txt.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "final time text", None, -1))
        self.final_time_lab.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "final time label", None, -1))
        self.final_time_lab.setText(QtWidgets.QApplication.translate("init_val_prob_dialog", "final time", None, -1))
        self.step_time_txt.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "step time text", None, -1))
        self.step_time_lab.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "step time label", None, -1))
        self.step_time_lab.setText(QtWidgets.QApplication.translate("init_val_prob_dialog", "step time", None, -1))
        self.tolerance_lab.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "tolerance label", None, -1))
        self.tolerance_lab.setText(QtWidgets.QApplication.translate("init_val_prob_dialog", "tolerance", None, -1))
        self.tolerance_txt.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "tolerance text", None, -1))
        self.max_iter_lab.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "max iterations label", None, -1))
        self.max_iter_lab.setText(QtWidgets.QApplication.translate("init_val_prob_dialog", "max iterations", None, -1))
        self.max_iter_txt.setAccessibleName(QtWidgets.QApplication.translate("init_val_prob_dialog", "max iterations text", None, -1))
class init_val_prob_dialog(QtWidgets.QDialog, Ui_init_val_prob_dialog):
    def __init__(self):
        super(init_val_prob_dialog, self).__init__
        self.setupUi
        self.show
ivpDia = init_val_prob_dialog()
ivpDia.show
vocx
Re: dialog box will not show
Postby vocx » Wed Sep 11, 2019 1:04 am
    def __init__(self):
        self.setupUi
        self.show
ivpDia.show
These are functions, right? So you should call them.
        super(init_val_prob_dialog, self).__init__()
        self.setupUi()
        self.show()
If you don't write the parentheses, you are just treating them as variables (they return the reference to their internal object).
mfasano
Postby mfasano » Wed Sep 11, 2019 6:43 pm
        self.setupUi()
        self.show()
I tried that and I got an error that says I need an argument for setupUi(). I don't know what the argument shoud be for this method.
  File "C:/Users/Matt/AppData/Roaming/FreeCAD/dialogtest.FCMacro", line 100, in <module>
  File "C:/Users/Matt/AppData/Roaming/FreeCAD/dialogtest.FCMacro", line 95, in __init__
    self.setupUi()
<class 'TypeError'>: setupUi() missing 1 required positional argument: 'init_val_prob_dialog'
vocx
Postby vocx » Wed Sep 11, 2019 7:05 pm
Did you write this code yourself, or was it created automatically from QtCreator or something like that?
The definition of the method within the class expects one argument init_val_prob_dialog
The argument init_val_prob_dialog is exactly the name of the second class, so maybe in this second class you need to pass self, which is precisely a reference to itself (the init_val_prob_dialog class).
    def __init__(self):
        self.setupUi(self)
        self.show()
mfasano
Postby mfasano » Thu Sep 12, 2019 12:38 pm
Thanks vocx for the help.
The class Ui_init_val_prob_dialog(object) is generated using pyside2-uic from a UI file. the other class init_val_prob_dialog(QtWidgets.QDialog, Ui_init_val_prob_dialog) is something I copied from somewhere.
including self as an argument in .setupUi worked. Now it has a problem with strings in the class Ui_init_val_prob_dialog(object). It is strange because this is Qt generated code. I think Qt has their prefered type for strings.
the error message i get
    self.setupUi(self)
  File "C:/Users/Matt/AppData/Roaming/FreeCAD/dialogtest.FCMacro", line 24, in setupUi
<class 'RuntimeError'>: '__init__' method of object's base class (init_val_prob_dialog) not called.
offending code
mario52
Postby mario52 » Thu Sep 12, 2019 1:30 pm
hi
tray this "essais"
#from __future__ import unicode_literals
# Squelette du programme.py avec " setupUi "
# il faut que le widget s'appelle MainWindow
*   Copyright (c)  xxxx <name>                      *
*   This file is a supplement to the FreeCAD CAx development system.      *
*   This program is free software; you can redistribute it and/or modify  *
*   it under the terms of the GNU Lesser General Public License (LGPL)    *
*   as published by the Free Software Foundation; either version 2 of     *
*   the License, or (at your option) any later version.                   *
*   for detail see the LICENCE text file.                                 *
*   Use at your own risk. The author assumes no liability for data loss.  *
*              It is advised to backup your data frequently.              *
*             If you do not trust the software do not use it.             *
*   This software is distributed in the hope that it will be useful,      *
*   but WITHOUT ANY WARRANTY; without even the implied warranty of        *
*   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the         *
*   GNU Library General Public License for more details.                  *
*   You should have received a copy of the GNU Library General Public     *
*   License along with this macro; if not, write to the Free Software     *
*   Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  *
*   USA        *
*           WARNING! All changes in this file will be lost and            *
*                  may cause malfunction of the program                   *
#Macro_Spring_Helix_Variable 10/11/2014 /_03
#OS: Windows 10 (10.0)
#Word size of OS: 64-bit
#Word size of FreeCAD: 64-bit
#Version: 0.19.18024 (Git)
#Build type: Release
#Branch: master
#Hash: 9cc8f6eb666b0a0ae2dc256f7bc0beb8c987710c
#Python version: 3.6.8
#Qt version: 5.12.1
#Coin version: 4.0.0a
#OCC version: 7.3.0
__title__   = "Titre"
__author__  = "Auteur"
__url__     = "http://www.freecadweb.org/index-fr.html"
__Wiki__    = "http://www.freecadweb.org/wiki/index.php?title="
__version__ = "00.00"
__date__    = "04/05/2019"
import PySide2
from PySide2 import QtGui ,QtCore, QtWidgets
from PySide2.QtGui import *
from PySide2.QtCore import *
import time
import Draft, Part, PartGui, FreeCADGui, FreeCAD
from FreeCAD import Base
import math
from math import sqrt, pi, sin, cos, asin
Gui = FreeCADGui
App = FreeCAD
#####paste here class Ui_MainWindow(object) begin#############################
#______________________________________________________________________________________
# mettre le code QT ici dessous #______________________________________________________
class Ui_MainWindow(object):
    def __init__(self ):
        self.window = MainWindow
        #self.path  = FreeCAD.ConfigGet("AppHomePath")
        #self.path  = FreeCAD.ConfigGet("UserAppData")
        #self.path  = "your path"
        param = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Macro")# macro path
        self.path = param.GetString("MacroPath","") + "/"                   # macro path
        self.path = self.path.replace("\\","/")
#        print("Path for the icons : " , self.path)
    def setupUi(self, MainWindow):
        MainWindow.setObjectName("MainWindow")
        MainWindow.resize(400, 300)
        self.PB_Quit = QtWidgets.QPushButton(MainWindow)
        self.PB_Quit.setGeometry(QtCore.QRect(215, 240, 156, 32))
        self.PB_Quit.setObjectName("PB_Quit")
        self.PB_Quit.clicked.connect(self.on_PB_Quit_clicked) ###
        self.PB_Validate = QtWidgets.QPushButton(MainWindow)
        self.PB_Validate.setGeometry(QtCore.QRect(215, 200, 156, 32))
        self.PB_Validate.setObjectName("PB_Validate")
        self.PB_Validate.clicked.connect(self.on_PB_Validate_clicked) ###
        self.int_time_txt = QtWidgets.QLineEdit(MainWindow)
        self.init_time_lab = QtWidgets.QLabel(MainWindow)
        self.final_time_txt = QtWidgets.QLineEdit(MainWindow)
        self.final_time_lab = QtWidgets.QLabel(MainWindow)
        self.step_time_txt = QtWidgets.QLineEdit(MainWindow)
        self.step_time_lab = QtWidgets.QLabel(MainWindow)
        self.tolerance_lab = QtWidgets.QLabel(MainWindow)
        self.tolerance_txt = QtWidgets.QLineEdit(MainWindow)
        self.max_iter_lab = QtWidgets.QLabel(MainWindow)
        self.max_iter_txt = QtWidgets.QLineEdit(MainWindow)
        self.retranslateUi(MainWindow)
        init_val_prob_dialog.setWindowTitle(QtWidgets.QApplication.translate("Ui_MainWindow", "initial value problem", None, -1))
        self.PB_Quit.setText(QtWidgets.QApplication.translate("Ui_MainWindow", "Quit", None, -1))
        self.PB_Validate.setText(QtWidgets.QApplication.translate("Ui_MainWindow", "Validate", None, -1))
        self.int_time_txt.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "initial time text", None, -1))
        self.init_time_lab.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "initial time label", None, -1))
        self.init_time_lab.setText(QtWidgets.QApplication.translate("Ui_MainWindow", "initial time", None, -1))
        self.final_time_txt.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "final time text", None, -1))
        self.final_time_lab.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "final time label", None, -1))
        self.final_time_lab.setText(QtWidgets.QApplication.translate("Ui_MainWindow", "final time", None, -1))
        self.step_time_txt.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "step time text", None, -1))
        self.step_time_lab.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "step time label", None, -1))
        self.step_time_lab.setText(QtWidgets.QApplication.translate("Ui_MainWindow", "step time", None, -1))
        self.tolerance_lab.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "tolerance label", None, -1))
        self.tolerance_lab.setText(QtWidgets.QApplication.translate("Ui_MainWindow", "tolerance", None, -1))
        self.tolerance_txt.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "tolerance text", None, -1))
        self.max_iter_lab.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "max iterations label", None, -1))
        self.max_iter_lab.setText(QtWidgets.QApplication.translate("Ui_MainWindow", "max iterations", None, -1))
        self.max_iter_txt.setAccessibleName(QtWidgets.QApplication.translate("Ui_MainWindow", "max iterations text", None, -1))
# mettre le code QT ici dessus  #______________________________________________________
        MainWindow.setWindowTitle(QtWidgets.QApplication.translate("MainWindow", __title__+" ("+__version__+", "+__date__+")"))
#        MainWindow.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)                # PySide2 cette fonction met la fenetre en avant
        MainWindow.setWindowFlags(PySide2.QtCore.Qt.WindowStaysOnTopHint)        # PySide2 cette fonction met la fenetre en avant
# mettre le code PY ici dessous #______________________________________________________
    def on_PB_Quit_clicked(self):
        self.window.hide()                                                  # hide the window and close the macro
        print("Quit ")
    def on_PB_Validate_clicked(self):
        print("Hello Welcome to FreeCAD")
doc = FreeCAD.ActiveDocument
if doc == None:
    doc = FreeCAD.newDocument()
MainWindow = QtWidgets.QWidget()    #PySide2
ui = Ui_MainWindow()
ui.setupUi(MainWindow)
MainWindow.show()
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
vocx
Postby vocx » Thu Sep 12, 2019 4:49 pm
Well, this doesn't mention anything about strings.
What I do notice is your first class doesn't have an __init__() method. Maybe define one?
    def __init__(self):
        pass
The second class inherits from the first class. What the following instruction does is that inside its own __init__() function, first it calls the __init__() function of the parent class. Therefore, the parent's __init__() must exist.
    def __init__(self):
mfasano
Postby mfasano » Fri Sep 13, 2019 6:29 pm
I found that the argument for .setupUi() should be QtWidgets.QDialog as Mario does.
    def __init__(self):
        self.setupUi(QtWidgets.QDialog)
now I get this error
  File "C:/Users/Matt/AppData/Roaming/FreeCAD/dialogtest.FCMacro", line 96, in <module>
  File "C:/Users/Matt/AppData/Roaming/FreeCAD/dialogtest.FCMacro", line 94, in __init__
<class 'TypeError'>: descriptor 'setObjectName' requires a 'PySide2.QtCore.QObject' object but received a 'str'
I don't understand this; the argument for .setObjectName is supposed to be unicode. I thought python strings were unicode.
vocx
Postby vocx » Fri Sep 13, 2019 7:15 pm
    def __init__(self):
Where did you find this information? Are you just trying things?
Forget about other code; in your code the setupUi() function needs an init_val_prob_dialog. This is the current class, so you need to use self.
Look, this runs in my system.
    def __init__(self):
        pass
    def __init__(self):
        self.setupUi(self)
        self.show()
ivpDia.show()
Is this what you want?
I'm using Qt 5.9.5. Maybe your version of Qt is different and thus it fails on something.
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.18195 +1 (Git)
Build type: Unknown
Branch: Draft_CubicBezCurve
Hash: 329863111c71285f59db471a783b46d345688d30
Qt version: 5.9.5
mfasano
Postby mfasano » Mon Sep 16, 2019 11:24 pm
I thought I would try reinstalling FreeCad.
Version: 0.18.16131 (Git)
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Qt version: 5.6.2
It said no module named pyside2 at the line for import.
I tried to install pyside2 with pip install. I made the environment path so freecad python was used. I also used sys.path.append to include freecad directories.
I guess I am moving backwards.
import os
import sys
sys.path.append('''C:\\Program Files\\FreeCAD 0.18\\bin''')
sys.path.append('''C:\\Program Files\\FreeCAD 0.18\\bin\\Scripts''')
sys.path.append('''C:\\Program Files\\FreeCAD 0.18\\Ext''')
# Created: Wed Aug 14 12:55:13 2019')
from pyside2 import QtCore, QtGui, QtWidgets
    def __init__(self):
        self.setupUi(self)
ivpDia.show()
  File "C:/Users/Matt/AppData/Roaming/FreeCAD/dialogtest.FCMacro", line 26, in <module>
<class 'ModuleNotFoundError'>: No module named 'pyside2'
