Constraints not visible while sketching
dineshlama007
Postby dineshlama007 » Thu Sep 12, 2019 5:22 am
I am using FC version 0.18. I'm following https://www.youtube.com/watch?v=1JFvtkKbxBI&t=297s tutorial to sketch. But when i am drawing lines using polygon tool, it is not showing any type of constraints like if it is perpendicular, parallel etc. Since constraints are very important while sketching, i'm stuck in this problem.
Screenshot from 2019-09-12 11-06-12.png (2.78 KiB) Viewed 392 times
microelly2
Re: Constraints not visible while sketching
Postby microelly2 » Thu Sep 12, 2019 6:40 am
one tipp: Auto constraints should be on to generate the constraints during drawing.
2019-09-12 08_37_15-FreeCAD 0.18.png (3.98 KiB) Viewed 377 times
dineshlama007
Postby dineshlama007 » Thu Sep 12, 2019 10:39 am
They are checked.
Screenshot from 2019-09-12 16-22-34.png (37.4 KiB) Viewed 366 times
Screenshot from 2019-09-12 16-22-55.png (30.82 KiB) Viewed 366 times
openBrain
Postby openBrain » Thu Sep 12, 2019 11:18 am
Are constraints visible if you add eg. a rectangle or slot ?
Postby chrisb » Thu Sep 12, 2019 1:25 pm
Try switching autoconstraints of and on again, in case autoconstraints are switched off for this sketch. There is a known issue concerning this.
