Feature: Automatically select created object
blasVuwi
Postby blasVuwi » Fri Sep 13, 2019 8:07 am
Hello ;)
Is there a way to automatically select an object after creating it? Right now if I create a rectangle, I have to then select it, then hit Wall (in Arch), then select that wall, then resize it. It would be nice if creation operations would automatically select the object they created, wouldn't it?
OS: Arch Linux
Version: 0.18.16131 (Git)
Branch: makepkg
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.7.4
Qt version: 5.13.0
vocx
Re: Feature: Automatically select created object
Postby vocx » Fri Sep 13, 2019 9:34 am
Is there a way to automatically select an object after creating it?...
I am using version 0.19, what you want is possible in my system. I'm not sure if this is a difference between the version, or maybe in your case it doesn't work. I don't remember if in 0.18 I didn't see this behavior.
The Draft code (I assume you mean Draft Rectangle) normally runs a function Draft.select(obj), which selects the object that was just created; so this is normal for most Draft and Arch tools.
https://github.com/FreeCAD/FreeCAD/blob ... ft.py#L789
def makeRectangle(length, height, placement=None, face=None, support=None):
    if not FreeCAD.ActiveDocument:
        FreeCAD.Console.PrintError("No active document. Aborting\n")
        return
    if placement: typecheck([(placement,FreeCAD.Placement)], "makeRectangle")
    obj = FreeCAD.ActiveDocument.addObject("Part::Part2DObjectPython","Rectangle")
    _Rectangle(obj)
    obj.Length = length
    obj.Height = height
    obj.Support = support
    if face != None:
        obj.MakeFace = face
    if placement: obj.Placement = placement
    if gui:
        _ViewProviderRectangle(obj.ViewObject)
        formatObject(obj)
        select(obj)
    return obj
