Feature Request: default file type when export
RafaelRS
Postby RafaelRS » Tue Sep 17, 2019 7:42 am
Currently when you do export (and i am doing it to STL) it always offer first to export to AMF type. So i have every time to scroll file types to select STL. That's annoying when you do it several times:
- export
- open in Cura to print or find corrections to do
- correct in FreeCAD
- export again
and that may repeat many times.
And that's annoying that i have every time to select file type.
Best option will be have some setting says file type used to export everytime by default.
Also suggestion about file name while export to do it not blank, but filename of current editing FCStd file OR name of model you selected to export (this prefferable to be able tune by settings too)
bernd
Re: Feature Request: default file type when export
Postby bernd » Tue Sep 17, 2019 9:58 am
These are surely good points! For me it is not stl but ifc instead. You should make a feature request on mantis in this regard.
Postby chrisb » Tue Sep 17, 2019 10:06 am
This is at least partly system dependent. On MacOS I get the last selection, I only have to fill in a filename. If you use Ubuntu you can choose to use the native system dialog. Perhaps that works better.
Nevertheless I think too you should create a ticket - unless there is already one, which is to be checked.
Jee-Bee
Postby Jee-Bee » Tue Sep 17, 2019 10:26 am
Isn't this WB dependend?
When exporting a fileformat from a WB that isn't used yet could create a situation that the file should be exported to a file format that isn't known by the system yet...
openBrain
Postby openBrain » Tue Sep 17, 2019 11:06 am
Also you can quite easily automate things in a macro. ;)
openBrain
Postby openBrain » Tue Sep 17, 2019 11:58 am
Eg. this will export selected objects in the same folder as FC file, with same name except STL extension :
import Mesh
fn = App.ActiveDocument.FileName
sel = Gui.Selection.getSelection()
if fn != '' and len(sel) > 0:
    en = fn[:fn.rfind('.')] + '.stl'
    ret = Mesh.export(Gui.Selection.getSelection(),en)
    App.Console.PrintMessage("\nExported selected object of " + fn + " to " + en)
elif fn == '':
    App.Console.PrintError("\nActive document has no filename, not able to export")
else:
    App.Console.PrintError("\nNo object selected, canceled")
You can bind it to a custom icon & keyboard shortcut. ;)
ExportSTL.FCMacro
(449 Bytes) Downloaded 7 times
