Is it possible to Loft/Sweep Facebinders?
Tilarta
Postby Tilarta » Sat Sep 28, 2019 6:53 am
Is it possible to Loft or Sweep these Facebinders to make them into a singular solid shape?
The program wouldn't perform the function with these objects, but I am wondering if there is a similar way to enact the same procedure with a different tool or function.
DBSnSword01.FCStd
(68.58 KiB) Downloaded 6 times
papyblaise
Re: Is it possible to Loft/Sweep Facebinders?
Postby papyblaise » Sat Sep 28, 2019 7:36 am
Hello again
fuse upper and lower and do chanfer , (I can't stop myself and I do sharp on the blade too :lol: )
tip sword.PNG (44.57 KiB) Viewed 118 times
sword.FCStd
(85.06 KiB) Downloaded 2 times
Tilarta
Postby Tilarta » Sat Sep 28, 2019 12:49 pm
Jello papyblaise.
The technique you showed me above gave me an idea for how to solve the problem:
Thank you for the inspiration and solution.
This is fairly close to the final appearance of the sword, now I just have to finish the fuel line and trim down the upper blade base.
The upper blade base is just a decorative line across the sword, it was never meant to be a cutting edge.
