Ticket #4145 - build failure with assembly module enabled
efferre
Postby efferre » Mon Sep 30, 2019 9:55 am
when building freecad using Genoo Linux I get the following error related to the Assembly module:
[ 95%] Building CXX object src/Mod/TechDraw/Gui/CMakeFiles/TechDrawGui.dir/ViewProviderSymbol.cpp.o
cd /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/Gui && /usr/bin/ccache /usr/bin/x86_64-pc-linux-gnu-g++ -DHAVE_CONFIG_H
 -DHAVE_LIMITS_H -DMOD_TECHDRAW_HANDLE_FACES=1 -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_PRINTSUPPORT_LIB -DQT_SVG_LIB
 -DQT_UITOOLS_LIB -DQT_WIDGETS_LIB -DQT_XMLPATTERNS_LIB -DQT_XML_LIB -DTechDrawGui_EXPORTS -D_OCC64 -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-
9999_build -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src -I/var/tmp
/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/Gui -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/TechDraw/G
ui -I/usr/include/coin -I/usr/include/python2.7 -I/usr/lib64/opencascade-7.3.0/ros/lin/inc -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtXmlPattern
s -isystem /usr/include/qt5/QtNetwork -isystem /usr/include/qt5/QtCore -isystem /usr/lib64/qt5/mkspecs/linux-g++ -isystem /usr/include/qt5/QtXml -isystem /
usr/include/qt5/QtWidgets -isystem /usr/include/qt5/QtGui -isystem /usr/include/qt5/QtOpenGL -isystem /usr/include/qt5/QtPrintSupport -isystem /usr/include
/qt5/QtSvg -isystem /usr/include/qt5/QtUiTools -DNDEBUG -Wall -Wextra -Wno-write-strings -march=core2 -O2 -pipe -ggdb -fPIC -fPIC -std=gnu++11 -o CMake
Files/TechDrawGui.dir/ViewProviderSymbol.cpp.o -c /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/TechDraw/Gui/ViewProviderSymbol.cpp
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp: In member function ‘void AssemblyGui::ViewProvid
erConstraintInternal::updateVis(const TopoDS_Shape&)’:
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp:85:23: error: no matching function for call to ‘A
ssemblyGui::ViewProviderConstraintInternal::updateVisual(const TopoDS_Shape&)’
     updateVisual(shape);
In file included from /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Part/Gui/ViewProvider.h:28,
                 from /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.h:27,
                 from /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp:24:
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Part/Gui/ViewProviderExt.h:150:10: note: candidate: ‘void PartGui::ViewProviderPartExt::u
pdateVisual()’
     void updateVisual();
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Part/Gui/ViewProviderExt.h:150:10: note: candidate expects 0 arguments, 1 provided
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp: In member function ‘virtual void AssemblyGui::Vi
ewProviderConstraint::setDisplayMode(const char*)’:
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp:110:57: warning: unused parameter ‘ModeName’ [-Wu
nused-parameter]
 void ViewProviderConstraint::setDisplayMode(const char* ModeName)
erConstraint::draw()’:
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp:255:20: error: no matching function for call to ‘AssemblyGui::ViewProviderConstraint::updateVisual(TopoDS_Shape&)’
     updateVisual(s1);
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Part/Gui/ViewProviderExt.h:150:10: note: candidate: ‘void PartGui::ViewProviderPartExt::updateVisual()’
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp: In member function ‘virtual void AssemblyGui::ViewProviderConstraint::onSelectionChanged(const Gui::SelectionChanges&)’:
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp:336:78: warning: unused parameter ‘msg’ [-Wunused-parameter]
 void ViewProviderConstraint::onSelectionChanged(const Gui::SelectionChanges& msg)
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp: In member function ‘virtual TopoDS_Shape AssemblyGui::ViewProviderConstraint::getConstraintShape(int)’:
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp:353:61: warning: unused parameter ‘link’ [-Wunused-parameter]
 TopoDS_Shape ViewProviderConstraint::getConstraintShape(int link)
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp: In member function ‘virtual bool AssemblyGui::ViewProviderConstraint::setEdit(int)’:
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp:416:42: warning: unused parameter ‘ModNum’ [-Wunused-parameter]
 bool ViewProviderConstraint::setEdit(int ModNum)
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp: In member function ‘virtual void AssemblyGui::ViewProviderConstraint::unsetEdit(int)’:
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/Mod/Assembly/Gui/ViewProviderConstraint.cpp:440:44: warning: unused parameter ‘ModNum’ [-Wunused-parameter]
 void ViewProviderConstraint::unsetEdit(int ModNum)
make[2]: *** [src/Mod/Assembly/Gui/CMakeFiles/AssemblyGui.dir/build.make:182: src/Mod/Assembly/Gui/CMakeFiles/AssemblyGui.dir/ViewProviderConstraint.cpp.o] Error 1
make[2]: Leaving directory '/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build'
make[1]: *** [CMakeFiles/Makefile2:4735: src/Mod/Assembly/Gui/CMakeFiles/AssemblyGui.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
probably the build failure is related to the commit 6da72b9859f6d21119831d44a8d132c8e2dfb544 where someone left behind assembly module.
If the assembly module is deprecated probably it's better to remove it from the tree to avoid such kind of problems or by making it impossible to enable during configuration time.
I have opened also the ticket issue #4145
Reason: Added ticket number to thread title
vocx
Re: build failure with assembly module enabled
Postby vocx » Mon Sep 30, 2019 3:54 pm
I think git commit 6da72b9859 is part of the big merge of App::Link from realthunder.
I'm having trouble understanding what you are reporting.
First of all, according to your bug report, you have this version
OS: Gentoo/Linux
Version: 0.19.16776 (Git)
Branch: (HEAD detached at refs/git-r3/HEAD)
Hash: b547373f35c3fd2a12fca5035af575c835062056
Python version: 2.7.15
Qt version: 5.11.3
This isn't the most recent version. The current master branch has 1580 more commits than your version of the source. I just compiled this right now without errors.
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.18356 (Git)
Hash: 12335c7d52376c140c5328d57902d2c0afdeb588
Python version: 3.6.8
Qt version: 5.9.5
The assembly workbench in the source code is basically old prototype code; it is right now a placeholder for when a real Assembly workbench is developed. However, it is completely deactivated currently; it is not built by default, and it has been like that for a long time. I've never had any compilation errors regarding assembly inside Mod/; therefore, I have to assume this is a problem with the way you are compiling, and not with FreeCAD itself.
cmake -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3 -DCMAKE_BUILD_TYPE=Release ../freecad-source-vocx && make -j3
truf
Re: Ticket #4145 - build failure with assembly module enabled
Postby truf » Fri Oct 18, 2019 8:19 pm
I can confirm this the issue with the way we configure/compile FreeCAD
I'm also having Gentoo and tried to enable all the modules including disabled by default assembly :)
Once disabled that assembly module i see no issues with compilation
efferre
Postby efferre » Mon Dec 02, 2019 10:18 am
OS: Gentoo/Linux
Qt version: 5.11.3
I am sorry for the latency but I didn't receive any notification about your reply :-(
I have tested today updating from the repository (commit e583b2a468c09ec11b5e1287ff94fd8914b824dc) so I am updated. The result is the same and the error is identical to the one reported at the beginning. I am using gcc 8.3.0
Ok, if it's kept as a reference I would say it must at least compile successfully :-) In the past I have already sent a pull request to fix build problems when the assembly module option is activated, in this case the issue is out of my knowledge and I am not able to fix it by myself.
I have not problems in compiling freecad, the building process only fails with -DBUILD_ASSEMBLY=ON (which is by default disabled as you say above).
What happens if you insert also the -DBUILD_ASSEMBLY=ON option to your flags? Which compiler version are you using?
ezzieyguywuf
Postby ezzieyguywuf » Mon Dec 02, 2019 10:52 pm
I agree with this: if the user is able to select a portion of the code base in the build system, then it should compile.
If the only reason to keep the code is for reference, then we should remove the BUILD_ASSEMBLY cmake variable altogether, so that it is impossible to try and compile this old code.
Who knew there were so many of us gentoo users around!
This is off-topic, but I’ve been toying with and compiling freecad In gentoo for years now, so if you have any issues or questions please feel free to reach out via ping or dm
vocx
Postby vocx » Tue Dec 03, 2019 12:52 am
Ok, if it's kept as a reference I would say it must at least compile successfully ...
No. Do not compile the Assembly workbench. It doesn't work. I don't understand why you try to compile it. It hasn't been updated or maintained by anybody in ages. You don't need to do anything with it. Unless you are going to pick it apart to learn more about the code, there is no point in using it. Just leave it there.
waebbl
Postby waebbl » Mon Dec 23, 2019 5:37 pm
I'm maintaining a gentoo build script for freecad for some time. I also have an option for users to enable them building with assembly workbench enabled. This is so, simply because the cmake files list an option for it. I'm now going to disable the option for gentoo users in my build script.
In this point I totally agree with @efferre that it should compile, if the cmake file lists an option for it. A new user who is just downloading the source code and trying to compile it, doesn't know, the code for assembly being there just for reference and might enable it, if interested in having a version with as much functionality enabled as possible.
vocx
Postby vocx » Mon Dec 23, 2019 7:01 pm
... if interested in having a version with as much functionality enabled as possible.
This makes no sense. The default CMake configuration already provides the most common and complete configuration.
Trying to activate all options without knowing what they do doesn't make sense. It's like trying to install every single package in a Linux repository. It's crazy.
You want to change the situation? Then you are welcome to fix the assembly workbench and make it compile with a current system. None of the other developers have enough interest in changing the situation, so they haven't done it already.
waebbl
Postby waebbl » Tue Dec 24, 2019 8:54 pm
It makes sense on a Gentoo system, where users have the option to enable or disable specific features / options for packages they wish to install. It's freedom of choice for the user. That's what Gentoo stands for.
It's up to the build system, both the upstream build system, as well as the gentoo side of the build to ensure the package can be built using the desired options. For the assembly option, I chose to disable it until there's an update to it upstream, as I alreday noted.
I do not want to change the situation. I'm not a FreeCAD developer and don't care a lot about this specific situation. I only care about the build and that the package can be delivered to the user, the way he or she likes it. BTW, if none of the developers currently care about the assembly workbench, what's the meaning of having an option for it in the cmake file? This option should be commented out until the workbench is back in a working state. At least a pointer noting that it doesn't build would be meaningful.
waebbl
Postby waebbl » Tue Dec 24, 2019 9:15 pm
BTW, I can disable the option, or add a comment to the cmakefile fragment and prepare a PR if it's desired.
