Impellar Turbine made in FreeCAD
pl7i92LCNC
Postby pl7i92LCNC » Wed Oct 02, 2019 8:57 am
Hi here i gone show you how to do a Fine Real build of a Impellar
phpBB [video]
for any critics i am open
Zolko
Re: Impellar Turbine made in FreeCAD
Postby Zolko » Wed Oct 09, 2019 11:07 am
I think that an impeller (radial compressor) has 2 stages, even though they are made in 2 part:
  • the central "inlet" part is close to an axial propeller, similar to what you have designed
  • a radial "exhaust" part, that doesn't appear in your design
pl7i92LCNC
Postby pl7i92LCNC » Wed Oct 09, 2019 3:08 pm
thank you
can you share your part if it is in FC design
i only got a 200mm 5Axis and not capable of AL it hat a 6mm BALLend bit 80mm long
did you make the g-code with fusion ?
Zolko
Postby Zolko » Wed Oct 09, 2019 3:18 pm
it's not my part, sorry for the misunderstanding, I got it when searching. I was just curious how you managed to do your impeller, that's how I saw your post.
But I don't see how you could machine your part, even with a 5-axis machine.
pl7i92LCNC
Postby pl7i92LCNC » Wed Oct 09, 2019 4:00 pm
thats why i fear 2
im waiting for a WIN10 PC to deliver
i only got Ubuntu
and Fusion needs win10
to get a Gcode build
pl7i92LCNC
Postby pl7i92LCNC » Wed Oct 09, 2019 6:12 pm
here is the NEW Sketch
hope you are fine with that one
impellar_5A.FCStd
(810.07 KiB) Downloaded 63 times
a smile for the Construct :)
Rana
Postby Rana » Thu Oct 31, 2019 5:33 pm
One try , seeing the image and assumed dimensions.
