A sketch scaling
koluna
Re: A sketch scaling
Postby koluna » Mon Oct 07, 2019 9:04 am
pl7i92LCNC wrote:
Mon Oct 07, 2019 8:34 am
this tutorial woudt be best
But I do not know Deutsch :(
if you only ned the outside select the shape in the extrude
all files SVG DXF inside the ZIP
Thanks a lot! :)
Have you made SVG in GIMP and imported SVG in FC?
My goal is to learn making it :)
Postby chrisb » Mon Oct 07, 2019 9:21 am
If you use the video tag - and if your video is the best tutorial ever, it deserves it - then you should allow to start it directly in the forum. If you don't want it, you should provide only a link.
openBrain
Postby openBrain » Mon Oct 07, 2019 9:37 am
Inkscape is the right tool to vectorize a picture and get an SVG from it. ;)
pl7i92LCNC
Postby pl7i92LCNC » Mon Oct 07, 2019 9:41 am
crisb
not native English im german
sorry i used the wrong frase
THIS VIDEO SHOWES HOW TO DO IT
phpBB [video]
Postby chrisb » Mon Oct 07, 2019 10:14 am
As this is the FreeCAD forum, we don't use Blender. You can directly import an SVG into FreeCAD and use it for further operations.
koluna
Postby koluna » Mon Oct 07, 2019 10:27 am
Thanks a lot, guys!
Do you think, my algorithm should be this?
1. Editing in GIMP (if it is needed).
2. Vectorize in Inkscape.
3. Import in FC and working with it.
openBrain
Postby openBrain » Mon Oct 07, 2019 1:42 pm
IMO you should do as much work as possible in Inkscape (cleaning, scaling, ...) before importing to FC so nothing but extrude is to be done. ;)
pl7i92LCNC
Postby pl7i92LCNC » Mon Oct 07, 2019 2:20 pm
i like to go over DXF the free LIBRECAD OR Freeversion of Qcad
this gives you a real clean file to import
but all workes also on librecad SVG to FC
koluna
Postby koluna » Mon Oct 07, 2019 2:32 pm
I used Inkscape and made an SVG file. It is ok.
I imported it into FC. The result is wrong. Why?
detskie-raskraski-krisa1.svg
(26.21 KiB) Downloaded 6 times
pl7i92LCNC
Postby pl7i92LCNC » Mon Oct 07, 2019 2:36 pm
as i did show in the Video
you need AFTER the vectorise to get the 2 Views seperated
thne delete the original RIGHT MOUSE Click
if it showes Filling and Contour its the Vector
if it does not its the image to be deleted
then Click again Right on the Vector
FILLING and Contour
X at Filling
and First low on contour
done export as standard svg
