Part->Chamfer does not work
pl7i92LCNC
Re: Part->Chamfer does not work
Postby pl7i92LCNC » Sun Oct 13, 2019 6:55 am
At this kind of work the cutter of the dough/dowgh is not the main consern
it is th inlay that makes you to need a bevel
you will final end up on a STL for printing and like cure 4.2 is closing the open edges on fileload
ofcause i agree a full green model is always the best to aproch
pl7i92LCNC
Postby pl7i92LCNC » Sun Oct 13, 2019 9:20 am
and her is the print that showes the layer does not match the fillet/Blend
so 0,4mm nozzel is not that best even at 80mm partzize 2mm contur height
offcause the cutter and the punchpad are sepperatet by 0,6mm at print and fit well
koluna
Postby koluna » Mon Oct 14, 2019 5:53 am
chrisb wrote:
Sat Oct 12, 2019 9:18 pm
koluna wrote:
Sat Oct 12, 2019 6:58 pm
But, how can I correct the self-intersection in a result Sweep?
I try to avoid this situation by either not having such sharp corners (radius of bends should exceed thickness of the sweep section) or I place the section appropriately.
Thanks. I think so. But sometimes is it impossible? :)
koluna
Postby koluna » Mon Oct 14, 2019 5:56 am
Thanks a lot! I will try to do so! :)
pl7i92LCNC
Postby pl7i92LCNC » Mon Oct 14, 2019 7:17 am
and here is patrick in full path mode as shown in the second part of the VIDEO tutorial
its within minutes to get a part but it is far from clear as of colorerd SVG
pl7i92LCNC
Postby pl7i92LCNC » Wed Oct 16, 2019 11:42 am
and the LAST effort
lets make cookies from FC Mold
Have fun and the kids do like it even made of Dinkel green and low shugar as it is a caracter cookie
koluna
Postby koluna » Thu Oct 17, 2019 7:22 am
They were a bit burnt ;)
Thanks a lot! I have already defined my way. I will work! :)
koluna
Postby koluna » Mon Oct 28, 2019 2:38 pm
Hi, guys!
It is an offtopic, but I am very sorry...
I have already done my form with Blender 2.80! :)
koluna
Postby koluna » Thu Jan 09, 2020 4:55 pm
Hi, guys!
OS: Linux Mint 18.1 Serena (MATE/mate)
Version: 0.19.
Python version: 3.5.2
How can I get a chamfer on my model?
It does not work...
8.7e-08 <App> Document.cpp(3462): Failed to recompute nut1#Chamfer: Resulting shape is invalid
Recompute failed! Please check report view.
nut2.FCStd
(53.69 KiB) Downloaded 7 times
Roy_043
Postby Roy_043 » Thu Jan 09, 2020 5:13 pm
You may have posted in the wrong topic as you are using the Part Design WB.
PartDesign_Chamfer seems sensitive to the selection order of the edges?
If I first select Edge26 and then the other edges in a CCW order the command works OK.
OS: Windows 8.1 (6.3)
Version: 0.19.19127 (Git)
Hash: ec18f070d13b195d946c3d955d8c21b2e60550e2
Python version: 3.6.8
Qt version: 5.12.1
