Use sketch for kinematic
kisolre
Postby kisolre » Wed Oct 09, 2019 6:01 pm
After this post https://forum.freecadweb.org/viewtopic.php?f=24&t=39967 I tried and succeeded in an experiment that I wanted to do for a long time - using a sketch to define placement of objects and create kinematic in sketch to act as an assembly. I noticed that Draft Clone has mapping mode and used that to map clones of the bodies to sketch edges and thus changing sketch moves the clones arround. I also used the kinematic sketch to define dimensions in bodies through CarboCopy.
phpBB [video]
OS: Windows 8.1 (6.3)
Version: 0.19.18504 (Git)
Hash: f66023a646db4b2502bb3637897443b3525ca3c7
Python version: 3.6.8
Qt version: 5.12.1
CrankShaftKinematic.FCStd
(38.99 KiB) Downloaded 44 times
Re: Use sketch for kinematic
Postby chrisb » Wed Oct 09, 2019 7:46 pm
Why do you use these clones? You could place the bodies directly.
kisolre
Postby kisolre » Wed Oct 09, 2019 8:29 pm
Because bodies can not be ATTACHED to things? They can be placed but they will not follow sketch changes.
ppemawm
Postby ppemawm » Wed Oct 09, 2019 10:17 pm
They can if they are created from a carboncopy of the master sketch.
In the example you referenced, there were eighteen (18) bodies created from multiple copies (Edit>duplicate selection) of a carboncopy of the single master sketch that represents and controls the position of the bodies in the subassembly.
"It is a poor workman who blames his tools..." ;)
kisolre
Postby kisolre » Thu Oct 10, 2019 5:54 am
There is a difference between the Body object and its actual geometry. In your master sketch approach you move the geometry of the body and not the body itself. And for that to succeed you need to have all placements/dimensions/relations/... in the master sketch. If you want to make an extra hole in the body you need to either add it to the master sketch or make another carboncopy sketch and add it there to keep the relationships.
In this approach you just need to have proper basic body orientation and very simple kinematic sketch. I used it as master for crankshafts crank length and connecting rod distance between heads but that is all. You are free to design your bodies as you want. You can also attach different kinematik sketches in sequence to define different mechanisms.
Postby chrisb » Thu Oct 10, 2019 5:25 pm
Thanks
kisolre
Postby kisolre » Sat Oct 12, 2019 6:57 am
Another WIP of an Excavator kinematic:
Rotating Sketch rotates the whole assembly. Changing HC1, HC2, HC3 (hydraulic cylinder) constraints in Sketch001 moves the arm.
One must pay attention to edge draw direction it it should be used for mapping later.
Qt version: 5.12.1
Excavator.FCStd
(75.21 KiB) Downloaded 19 times
ppemawm
Postby ppemawm » Sat Oct 12, 2019 3:31 pm
It would be helpful if you indicated what version you are using.
It seems that the expressions fail for V0.18 or early V0.19 with multiple error messages in the report view:
...Failed to parse expression.
No extension found of type 'PartGui::ViewProviderAttachExtension'...
But, I get no error for my current version, at least for small changes in the variables:
OS: Windows 10 (10.0)
Version: 0.19.18356 (Git)
Hash: 12335c7d52376c140c5328d57902d2c0afdeb588
Qt version: 5.12.1
In this approach you just need to have proper basic body orientation and very simple kinematic sketch....You are free to design your bodies as you want....
You have an interesting approach. I am trying to understand where you are going with this.
How one can design or model a new body "out-of-context" is beyond my skill set. E.g., how do you insure that the bodies are not going to interfere when placed in the assembly? If you are working from legacy drawings it is not a problem because the body envelopes have already been determined.
I have always used a top down approach even going back to the drawing board days, but I am open to the advantages of a different method. My next project will be to see if I can somehow blend the use of master sketches, in-context modelling, and an assembly workbench (A2plus?) to take advantage of the assembly constraint engine. Trying to control body positioning with a master sketch(es) can get quite complicated and error prone when working with complex assemblies.
kisolre
Postby kisolre » Sat Oct 12, 2019 5:11 pm
Added version info to posts with files. Those are created with latest 0.19_pre - after all changes with Link Merge. But the method should work with with older versions that have expressions. Might be that expression format changed after the Link Merge and older versions fail to parse it. I tried latest 0.19_pre version before the LinkMerge that I have and it also fails with some of the expressions.
I wanted to try something like a simple assembly without any workbench and since there was a solver already why not use it?
In those examples I just modeled something that looks like a real part. In the existing FreeCAD assembly workbenches you model your parts in a separate files so they are "out-of-context" by default. When I model real parts that should work together I usually select meaningful origin and orientation, design one part or at least what will mate with other parts. For the next part I again select meaningful origin and orientation, draw something in the first sketch so body will be visible and then move the second part to there it should be relative to the first and design it there.
But this is Ok just for a single state of the final assembly. And when you need to move them to check for interference it becomes a mess. So having the ability to move things around in a controlled dependent manner helps with that.
Designing a proper sketches and linking them together to properly represent desired relations is of course a challenge but for simple assemblies will do the trick.
Here I used kinematic sketch to define the parts lengths but it can be the other way around - use spreadsheet for basic dimensions and reference those in kinematic and design. Spreadsheet to avoid possible circular dependencies.
Zolko
Postby Zolko » Sat Oct 12, 2019 5:44 pm
Isn't this similar to the assembly without solver thing ?
That evolved to a proper assembly workbench (Assembly4), and I have the feeling you are doing very similar things. Did you check those threads ? Did you try to install/use Assembly4 workbench ?
Not necessarily: they must be created out-of-context, in their own file, you're right, but once they're in the assembly they can be edited and changed in-context.
Does this approach also work if you want to re-use a part several times ?
I very much like that approach, and I think you can build quite complex mechanisms in such way. Technically, most movements in real life happen anyway in 2D and are mostly combinations of rotation and translation.
