Thought this would be of interest to the FEM-Knights
Aka Knight-of-FEM
This is interesting for sure. I didn't know Paraview could open d3plots. That must mean the d3plot file format is well described in LS-Dyna's manual. I think I've seen it, I just didn't remember it.
Depends what a large deformation is ... CalculiX supports wide ranges of nonlinearity. For sure more than any commercial structural engineering (really structural engineering software) software I have seen so far. I even would not call CalculiX structural engineering software. Its main developer has been employer for decades at MTU. AFAIK marine engines are not structural objects ... and for sure marine engines analyses involves nonlinearity.
I think I'm using LS-Dyna's terminology, or what they call "explicit dynamics", which is solving for the equations of motion over time.
Or said in another way, can CalculiX produce that animation of the can being crushed? How would you set the boundary conditions on the moving plane and the contact surfaces?Code: Select all
Explicit: - Impact, penetration, high rate dynamics - Many small time steps - Courant condition limits longest stable time step - Conditionally stable - Robust, even for strongly non-linear models - Low memory requirements - Expensive to conduct long duration simulations Implicit: - Static, eigenvalue, low rate dynamic analysis - Few large time steps - Model size (degrees of freedom) affects wall time - Can be unconditionally stable - Eventually problematic for strongly non-linear models - High memory requirements (inverting stiffness matrix) - Relatively inexpensive for long duration analysis
vocx wrote: ↑Mon Oct 14, 2019 4:58 pmCode: Select all
you could give it a try with FreeCAD FEM ... https://forum.freecadweb.org/viewtopic. ... 10#p340974 but as said quite a few times this is not by buissiness since I am structural engineer.
