Support for placement and vector math in expressions
DeepSOIC
Postby DeepSOIC » Sat Oct 12, 2019 3:01 pm
Doesn't seem to be documented or announced yet, so:
Since FreeCAD 0.19.18350 (git commit 6b6c0a503ca129174790e5a3ebe2ab95b6e96597), thanks to Realthunder:
Vector, Placement and Matrix math is available in spreadsheets and expressions.
=Cylinder.Placement.Base * 2 to set a spreadsheet cell to have a vector value
=Cylinder.Placement to set a cell to a placement value
to create a vector/placement from scratch:
=create(<<vector>>, 2, 1, 2)
=create(<<rotation>>, create(<<vector>>, 0, 1, 0), 45)
=create(<<placement>>, some_vector_value, some_rotation_value)
Doesn't seem like there is a GUI way to bind expressions to placements and vectors. (Maybe in Asm4.) But it is possible with py console:
App.ActiveDocument.Cylinder.setExpression('Placement', 'Box.Placement') - to make placement of Cylinder follow placement of Box
App.ActiveDocument.Cylinder.setExpression('Placement', 'Box.Placement^0.5') - place cylinder halfway between box and origin (since 0.19.18519)
I picked these up from unit test code, check it out for more usage examples.
https://github.com/FreeCAD/FreeCAD/blob ... et.py#L876
realthunder wrote:
Sat Aug 31, 2019 7:47 am
Ding!
@realthunder, can you add something to this?
DeepSOIC
Re: Support for placement and vector math in expressions
Postby DeepSOIC » Sat Oct 12, 2019 3:32 pm
Oh, of course, more info here, in pull-request thread:
https://forum.freecadweb.org/viewtopic.php?f=27&t=38974
realthunder
Postby realthunder » Sat Oct 12, 2019 11:47 pm
You mean GUI ways of binding expression, or just some more info in general? Anyway, the GUI way of binding is hidden by default as I consider this as an advanced feature. Maybe we shall just make it default.
There is also this batch expression edit feature I talked about in the other thread. You can use treeview context menu 'Expression actions' to copy expressions of either the selected object, all objects of the active document, or all objects of all documents. Paste them to any text editor and edit it and paste it back. Paste back only modifies existing expression or create new bindings, it will not delete bindings. Try this with spreadsheets that have cell styles or alias, and you'll find you can batch edit those properties as well.
vocx
Postby vocx » Mon Oct 14, 2019 12:24 am
I have a question. Are View properties (view provider) in the Property editor able to use Expressions?
I don't remember if this worked before or not.
In the Draft Dimension command the start and end points are defined as "App::PropertyVectorDistance". The position of the dimension text (ViewObject.TextPosition) is also defined by an "App::PropertyVectorDistance". However, in the second case, there is no formula editor.
I'd like to be able to set
ViewObject.TextPosition.x = obj.End.x + 1mm
How would one use an object's property, from a viewprovider's property? Or vice versa?
realthunder
Postby realthunder » Mon Oct 14, 2019 12:47 am
It is not possible at the moment. The expression bindings are stored and processed by a property called ExpressionEngine that is contained in every document object. There is no such thing in view provider. It is of course possible to extend expression engine to support view property, but it is going to take quite some effort. A much simpler way is to change the implementation of Dimension. Either move the property to object, or add a new one to object, and sync the value in ViewObject.updateData().
vocx
Postby vocx » Mon Oct 14, 2019 4:25 am
...The expression bindings are stored and processed by a property called ExpressionEngine that is contained in every document object. There is no such thing in view provider. ...
I see. I never really thought about this until now. I'll see what makes most sense about changing the implementation.
