Sheet metal workbench questions on unfold and bend lines
Re: Can't unfold in the sheet metal workbench
Postby chrisb » Thu Oct 17, 2019 5:50 am
andrigtmiller wrote:
Thu Oct 17, 2019 4:22 am
Yes, I think that would be helpful.
Thanks for understanding. I changed the title. Feel free to change it yourself to so something better.
Re: Sheet metal workbench questions on unfold and bend lines
Postby chrisb » Thu Oct 17, 2019 6:07 am
Thu Oct 17, 2019 4:29 am
The reason this is important, is because I need to create a 2D drawing, using the TechDraw workbench, and show the measurements for all the bend lines.
I upload the file which was only a few clicks away from your model:
- start FreeCAD, load model, switch to SheetMetal
- select Unfold and delete it
- select Bend007 and make it visible
- select the bottom (from the inside)
- click "Flatten folded sheet metal object", check the boxes like this:
Snip macro screenshot-019ae5.png (34.86 KiB) Viewed 640 times
- click ok, you should see this:
Snip macro screenshot-bfedd5.png (35.88 KiB) Viewed 640 times
FuelCell_cb.FCStd
(93.67 KiB) Downloaded 23 times
andrigtmiller
Postby andrigtmiller » Fri Oct 18, 2019 12:29 am
Okay, I followed your directions, and I get the same results. No bend lines, and I don't get the sketches generated either.
This is beyond frustrating, because it seems to work fine for everyone else.
Postby chrisb » Fri Oct 18, 2019 7:12 am
You can try to reset the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
And you may try a recent 0.19 Appimage. Although easyw-fc reported that it works in 0.18 too, that wasn't explicitely for the bend lines.
easyw-fc
Postby easyw-fc » Fri Oct 18, 2019 11:57 am
If you enable the Report Panel, which messages you get?
andrigtmiller
Postby andrigtmiller » Fri Oct 18, 2019 3:23 pm
The messages are very long, but at the end, I get the following:
Unfold successful
19Standard_OutOfRange No OCCT Exception Message
File "/home/andrigtmiller/.FreeCAD/Mod/sheetmetal/SheetMetalUnfolder.py", line 2871, in accept
grp2 = Drawing.projectEx(co, norm)
<class 'Part.OCCError'>: 19Standard_OutOfRange No OCCT Exception Message
So, there is an error in the Python script, which may explain why I don't get the bend lines.
papyblaise
Postby papyblaise » Fri Oct 18, 2019 3:42 pm
from my 1st picture, I project the sketch on a Techdraw sheet, and Dim it (some of )
fold lines.FCStd
(112.54 KiB) Downloaded 11 times
easyw-fc
Postby easyw-fc » Fri Oct 18, 2019 4:36 pm
Unfold successful
This is an error in the execution related to your version of OCC
Mon Oct 14, 2019 4:19 am
OS: "Fedora release 30 (Thirty)"
Version: 0.18.Unknown
Build type: Unknown
Python version: 3.7.3
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18
andrigtmiller
Postby andrigtmiller » Sat Oct 19, 2019 12:18 am
Unfold successful
Build type: Unknown
Coin version: 3.1.3
Yes, this version of open cascade is very old, and the AppImage is using 7.3.0, so that is definitely the problem. I may switch to the AppImage for now, to get this done.
Thanks for helping with the report panel. I didn't think to do that.
andrigtmiller
Postby andrigtmiller » Sat Oct 19, 2019 2:46 am
Unfold successful
Build type: Unknown
Coin version: 3.1.3
Just wanted everyone who has helped out with this, that I have successfully gotten what I need by using the AppImage, instead of the Fedora 30 install. It works perfectly, and I opened a bug report against the Fedora distribution, since they are including such an old version of Open Cascade. The AppImage has 7.3.0, which is only one release behind the most current, which is 7.4.0, but the Fedora build is using 6.9.1.
