A simple question
charles1954
Re: A Not so simple question
Postby charles1954 » Mon Oct 28, 2019 4:23 am
I have been working my way through the tutorials, getting aquainted with as many of the features of FreeCad. I have spent all day on the Lego Block Tutorial, only to be confounded by: "Pad: Result has multiple solids. This is not supported at this time." error. I searched through the forum for posts related to this error. I spent the better part of two hours reading through many of them. My take on the problem was that in V0.16 the pad function worked as described, but mysterious problems cropped up later in the drawing. I saw that people were being advised to only work with tutorials for V0,17 and above. Earlier in the week I worked through the toothbrush head stand. I thought about that and went back and checked the procedure. I believe we performed a similar task in producing the cylinder protrusions on the top face of that part. It worked flawlessly. The difference in creating those pads was that we selected the top face of the base part to create our sketch on. I am going to stay up and give this a try with the Lego Block. I will report the success or failure of this later.
Thanks for making me think.
Charles
freedman
Re: A simple question
Postby freedman » Mon Oct 28, 2019 4:51 am
Every once in a while I post this write-up I did when I started. Maybe it will help you.
https://forum.freecadweb.org/viewtopic.php?f=21&t=29179
vocx
Postby vocx » Mon Oct 28, 2019 5:07 am
..."Pad: Result has multiple solids. This is not supported at this time." ...
See feature editing.
A PartDesign Body must be a single contiguous solid. A screw is a single contiguous solid. A screw and a nut are two different solids. Even if you screw them together, they are not fused together, they are still separate solids. The screw would be one PartDesign Body, and the nut would be a second PartDesign Body.
