Sketcher Arc Of Hyperbola Broken?
Trying to use this nice function, but no luck
Always get these NaNs
App.getDocument('Unnamed').getObject('Sketch').addGeometry(Part.ArcOfHyperbola(Part.Hyperbola(App.Vector(nan,nan,0),App.Vector(163.858917,117.976585,0),App.Vector(185.834732,69.798813,0)),nan,nan),False)
<class 'NameError'>: name 'nan' is not defined
version:
OS: Windows 10 (10.0)
Version: 0.19.18528 (Git)
Hash: 891f8953fe858d41600b41a62ebde48f91b0526a
Python version: 3.7.3
Qt version: 5.12.5
Re: Sketcher Arc Of Hyperbola Broken?
Confirmed on the version below (I guess it's been broken for a while).
OS: Ubuntu 16.04.6 LTS
Version: 0.18.1. dated 2019-04-30
Python version: 2.7.12
… here it works also (after some faulty trials!)
- Hyperbola.FCStd
- (7.28 KiB) Downloaded 29 times
- pl7i92LCNC
the appimage is ok wores fine
FreeCAD_0.19-18353-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
For me it works when you select carefully the points of the hyperbola. However I can also make it fail if I select the second helper line to be orthogonal to the first line. In this case the formula in DrawSketchHandlerArcOfHyperbola::releaseButton fails:
The argument of acosh() seems to become negative and thus the result gives a NaN (not-a-number). When building the Python string with the broken number then it adds nan to the expression and thus leads to an error because nan is not a defined identifier.
Here the exception handling should be improved by checking the values beforehand and in case of NaN an error should be reported:
git commit eb6a405c1
double angleatstartingpoint = acosh(((startingPoint.x-centerPoint.x)*cos(phi)+(startingPoint.y-centerPoint.y)*sin(phi))/a);
double endAngle = atanh( (((endPoint.y-centerPoint.y)*cos(phi)-(endPoint.x-centerPoint.x)*sin(phi))*a) /
(((endPoint.x-centerPoint.x)*cos(phi)+(endPoint.y-centerPoint.y)*sin(phi))*b) );
if b becomes zero, expression becomes inf
Should be caught too
if (boost::math::isnan(startAngle) || boost::math::isnan(endAngle)) {
sketchgui->purgeHandler();
Base::Console().Error("Cannot create arc of hyperbola from invalid angles, try again!\n");
return false;
If b becomes zero endAngle becomes NaN. So, this is already handled.if b becomes zero, expression becomes inf
