[SOLVED] FEM: elements do not stick together (invalid geometry?)
Roland
Postby Roland » Thu Oct 17, 2019 12:01 pm
Dear Forum,
My FEM calculations misbehave.
This my input:
This my output:
Obviously, the L-profile is not attached to the bottom plate. How can I arrange that?
Part is a compound made from faces and wires:
Part is invalid, says Part WB (I do not know what that exactly means):
Do you have any clues for me?
Best regards,
Roland
On:
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
Roland
Re: FEM: elements do not stick together (invalid geometry?)
Postby Roland » Thu Oct 17, 2019 1:06 pm
I found perhaps part of the answer.
To create a valid part: Select all, PartWB/Boolean/Union. This gives a Fusion that is "valid".
However, now FEM gives errors. I am analyzing this further, and shall revert soon.
Roland
Roland
[SOLVED] Re: FEM: elements do not stick together (invalid geometry?)
Postby Roland » Thu Oct 17, 2019 1:15 pm
All solved. After the Union command was done and the geo was "valid", I made a FEM mistake of incomplete definitions of shell plate thickness.
The Union command increased the amount of shells. (which I overlooked).
Suggestion: There are multiple FEM wikis around, only one of them mentioned the need of Fusion. Compare:
https://www.freecadweb.org/wiki/Manual: ... M_analyses
https://www.freecadweb.org/wiki/FEM_tutorial
Perhaps make this more uniform (I know ... time ...)
Thaks for this great software!
Roland
bernd
Re: [SOLVED] Re: FEM: elements do not stick together (invalid geometry?)
Postby bernd » Fri Oct 18, 2019 6:15 am
Hi Roland,
welcome to FreeCAD FEM.
You could get wiki write permissions and just add what you have encountered.
cheers bernd
Roland
Re: [SOLVED] FEM: elements do not stick together (invalid geometry?)
Postby Roland » Tue Nov 05, 2019 7:51 pm
Thanks, Bernd, for the suggestion to give wiki write permissions.
However, at this stage I am not competent to make proper use of it.
In stead, let me propose some adaptations to the wikis, for others to consider and implement where needed.
Best regards,
Roland
