[FIXED] Dimensions repeat their Arbitrary labels
aapo
Postby aapo » Thu Oct 17, 2019 1:12 pm
Hi!
I noticed that whenever I change a dimension format to "Arbitrary" in a recent TechDraw version, the text entered into the Format Spec box repeats twice. Also, setting "Arbitrary" to false causes any other characters than the numeric value (e.g., "%g") to have no effect, i.e., only the raw number is shown in the actual dimension. I also get a lot of warnings, even though the there is a format specifier in Dimension001, and the number actually shows in the dimension:
Warning - no numeric format in formatSpec - Dimension001
OS: Windows 10 (10.0)
Version: 0.19.18542 (Git)
Hash: 432d4f25528300d0febf53b85df578fcdde1eda7
Python version: 3.6.8
Qt version: 5.12.1
Syres
Re: [Bug?] Dimensions repeat their Arbitrary labels
Postby Syres » Thu Oct 17, 2019 3:45 pm
Confirmed using (and later builds):
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18516 (Git)
Hash: 867a09f731926bf75695e8a6f063cbc9c1033b40
Qt version: 5.12.1
Last correct working build was:
Version: 0.19.18504 (Git)
Hash: f66023a646db4b2502bb3637897443b3525ca3c7
Qt version: 5.12.1
therefore it is possible that commit https://github.com/FreeCAD/FreeCAD/commit/90fad81 may have caused the regression.
wandererfan
Postby wandererfan » Fri Oct 18, 2019 2:00 pm
should be fixed by git commit a1de871e93
aapo
Postby aapo » Sat Oct 19, 2019 7:38 pm
Thanks! This indeed fixes the bug with Arbitrary labels, the word "Text" in the screenshot below with build 18567 is shown only once, as it should. However, the smaller bug with formatted labels still exists with the latest master, which has your patch. If I put a Format Spec value of
(%.2f) x2
to the dimension, the result is shown in the screenshot below. Note that the value "10.00" shows in place of %.2f, but the braces and the text "x2" are not shown. Sometimes I use braces around helper dimensions in order to indicate that these are secondary dimensions, which can be calculated from other dimensions.
OS: Debian GNU/Linux bullseye/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.18567 (Git)
Hash: f8f52e6fcfd40ae6187fc5d4f883ffb3f747f3ef
Python version: 2.7.17rc1
aapo
Postby aapo » Sun Oct 20, 2019 9:51 pm
Now it works for me, after I compiled the very latest master. Apparently you had committed a new patch today, which solves the problem for builds larger than 18590. Thanks! :)
Version: 0.19.18591 (Git)
Hash: c6cd65916caf466ba174aa09044c96a20790a72f
wandererfan
Postby wandererfan » Sun Oct 20, 2019 11:05 pm
Just sat down to put out a notice, but you beat me to it. Thanks for testing!
