[SOLVED] Wrong sheet metal unfold dimensions?
Fra88
Postby Fra88 » Thu Oct 17, 2019 4:41 pm
Hello, I'm making some tests with the module sheet metal.
I made a simple bend with this parameters:
- sheet metal thickness= 1mm
- internal bend radius= 1mm
- bend configuration: 90° bend with Kfactor=0,5
other dimension are summarized on picture and FC file attached.
When I use the unfold command, I obtain a sheet metal long 198,356mm but, making some math calculation, the lenght should be equal to:
L1+L2+(T+Kf*T)*pi/4=98+98+(1+0,5*1)*pi/4=197,178mm
where L1 and L2 are the lenght of the straight plates, T=thikness, Kf=neutral factor, pi=3,14...
I don't understand where is the error.
Is there any configuration that I have to tune?
Attachments: FC file, picture with dimensions.
Best regards.
bend test.FCStd
(15.74 KiB) Downloaded 15 times
bend dimensions.png (5.89 KiB) Viewed 517 times
Fra88
Re: Wrong sheet metal unfold dimensions?
Postby Fra88 » Thu Oct 17, 2019 6:23 pm
Sorry there is a mistak in the formula.
The correct one is:
L1+L2+(Ri+Kf*T)*pi/4=98+98+(1+0,5*1)*pi/4=197,178mm
where L1 and L2 are the lenght of the straight plates, T=thikness, Kf=neutral factor, pi=3,14..., Ri=internal bend radius
Postby chrisb » Thu Oct 17, 2019 7:24 pm
I have a different formula which uses pi/2 and not pi/4.
Fra88
Postby Fra88 » Thu Oct 17, 2019 7:37 pm
Dear chrisb, thank you for your reply.
Yes you are right!!!
Sorry for my big mistake :oops: :oops:
Re: [SOLVED] Wrong sheet metal unfold dimensions?
Postby chrisb » Thu Oct 17, 2019 7:44 pm
There is another error in your formula. According to my book the formula is for an angle of 90° (or less):
L1+L2+(Ri+Kf*T/2)*pi/2=98+98+(1+0.5*1/2)*math.pi/2 = 197.963
which is exactly what SheetMetal WB delivers. Besides that, according to my book th K factor should be 0.6 for a ratio radius/thickness of 1
Fra88
Postby Fra88 » Thu Oct 17, 2019 8:08 pm
I think that dipend on the definition of Kf. In "my" formula Is defined as the ratio between neutral axes position taken from internal bend (t) and tickness: Kf=t/T.
I have found this definition in the file attached (i'm sorry It is in italian language). In this file neutral factor Is indicated with "e".
2009-10-28-CALCOLO_SVILUPPO_LAMIERA.pdf
(631.55 KiB) Downloaded 18 times
Fra88
Postby Fra88 » Thu Oct 17, 2019 8:16 pm
Look at Page 7, picture 8.
Postby chrisb » Thu Oct 17, 2019 10:47 pm
I'm afraid that with that formula you cannot use the same K factor as used in SheetMetal (or in my formula).
cron
