Problem with B-spline helix
Postby chrisb » Fri Oct 18, 2019 12:05 am
I have created a Helix for a spring with Macro FCSpring Helix Variable. The helix looks very good, but if I create a sweep with it, it looks rather garbled.
Snip macro screenshot-59b2a2.png (39.25 KiB) Viewed 571 times
mario wrote:ping
Is this an issue with B-spline or with the sweep?
spring.FCStd
(216.13 KiB) Downloaded 25 times
UR_
Re: Problem with B-spline helix
Postby UR_ » Fri Oct 18, 2019 5:30 am
comb of mario's bspline
Screenshot 006.png (23.96 KiB) Viewed 554 times
bspline discretized and re-interpolated by curves wb
Screenshot 007.png (26.59 KiB) Viewed 554 times
spring.FCStd
(557.31 KiB) Downloaded 24 times
Postby chrisb » Fri Oct 18, 2019 7:30 am
Seems like it's time to get engaged with Curves. I havent found the time yet, but whatever I see here in the forum looks great.
mario52
Postby mario52 » Sat Oct 19, 2019 12:07 pm
hi
the problem with my macro is : i cut the conference in x points (default 72 points (max 360 points)) and with the formula (as UR_) much more points and the point to point connection are shorter
see:
FCSpring Helix macro help needed
Spiralbohrer
the microelly2 method (what I need to do heu...2016)
Bspline abhängig parametrisch an Sketch hängen, wie?
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
