Newbie: How to measure to a fillet?
kevinz
Postby kevinz » Fri Oct 18, 2019 3:07 pm
OS: Ubuntu 18.04.3 LTS
Version: 0.18.3.
Hello, thank you for taking the time to read this. I'm new to CAD overall, and brand-new to FreeCAD.
I'm trying to design a part that's triangular in shape. All verticies are filleted with some radius. The baseline is horizontal. How can I set the height of the part to a specific distance from the baseline to a horizontal line tangent to the upper fillet?
Thanks, again, for your thoughts.
-Kevin
kevinz
Re: Newbie: How to measure to a fillet?
Postby kevinz » Fri Oct 18, 2019 3:29 pm
Sorry, should have mentioned that I'm trying to do this in the PartDesign Workbench.
-Kevin
pl7i92LCNC
Postby pl7i92LCNC » Fri Oct 18, 2019 4:38 pm
there is a mesure tool in every workbench
also there are makros to crap surten points like edges faces and mesure sistances
if it is a filley of part design just open the filley and you see the width
bejant
Postby bejant » Fri Oct 18, 2019 4:49 pm
Hi Kevin, and welcome! Because you're using Part Design I think you'd set the height in a Sketch. One way is to create and Constrain a Vertical Construction Line Segment from the center of the top fillet arc to the top of the fillet arc. Then apply a Vertical Distance Constraint from the top Endpoint of that Construction Line Segment to the base.
20191018a.FCStd
(5.56 KiB) Downloaded 7 times
OS: Ubuntu 16.04.6 LTS
Version: 0.18.1.
Python version: 2.7.12
kevinz
Postby kevinz » Tue Oct 29, 2019 8:15 pm
bejant, thanks so much for your guidance. I forgot about construction lines and how they could be used. I'll use your method to see if I can get it to work. I'm having trouble with some of the simplest things (see my latest post), and if I have any further questions, I'll get back to you.
Thanks, again, for your help.
-Kevin
