[Solved] Wrong orientations,... in DetailView
IngoMeier
Postby IngoMeier » Tue Oct 22, 2019 7:15 am
Solved with version 0.19.18620
Hi!
Seems to be similiar to (or same as):
Problems with DetailView (False Dimension) -> PR1786
[Solved] problems with DetailView -> git commit d48d014eb9
but still not solved (or back) in Version: 0.18.16131 (Git) or in Version: 0.19.18542 (Git)
Only Detail of Front and Detail6 of Bottom are ok.
Changing Rotation and Direction seems to have no (visible) effect.
Thanks,
Ingo
Test_DetailView2.FCStd
(54.65 KiB) Downloaded 14 times
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Re: Wrong orientations,... in DetailView
Postby chrisb » Tue Oct 22, 2019 8:59 am
Can you verify if it's solved in 0.19?
IngoMeier
Postby IngoMeier » Tue Oct 22, 2019 9:54 am
Hi Chris,
just tried with Version: 0.19.18542 (Git) -> it is the same.
Even recreated some DetailViews and made changes in the Sketch. -> still wrong
It is the 0.19_pre version of FreeCAD. Or did you have another Version in mind?
If yes, where to find it?
Thanks,
Ingo
Postby chrisb » Tue Oct 22, 2019 11:32 am
That's the version I had in mind.
wandererfan
Postby wandererfan » Wed Oct 23, 2019 11:42 pm
Should be fixed by git commit 789733d691
IngoMeier
Postby IngoMeier » Thu Oct 24, 2019 7:55 am
Hi Chris,
thank you very much!
Will this go into 0.18.4 and 0.19?
Thanks,
Ingo
Postby chrisb » Thu Oct 24, 2019 8:30 am
Hi Chris,
Herewith I forward your thanks to Master Of TechDraw wandererfan.
IngoMeier
Postby IngoMeier » Thu Oct 24, 2019 11:12 am
By "Chris" I mainly meant wandererfan. (But take the thanks for your work too!)
Isn't "Chris" his Name?
Found it here:
https://forum.freecadweb.org/viewtopic. ... 474#p25474
Postby chrisb » Thu Oct 24, 2019 12:46 pm
I hadn't realized that he got one of these seldom used fantastic names.
wandererfan
Postby wandererfan » Thu Oct 24, 2019 2:13 pm
It is in the master source code for 0.19 now. Any v0.19 executables built from here on should include it.
Should be possible to back port to 18, but I'll have to look.
To Wiser Heads: does this meet the criteria for backports?
