Number of nodes limitation - Calculix error 201
Jckcdt
Postby Jckcdt » Tue Oct 22, 2019 9:13 am
I have a recurrent problem using the FEM module of Freecad.
As soon as GMSH creates more than about 350.000 nodes, I have a message error “Calculix error 201” during calculation.
Do you know if/how it would be possible to exceed this number of nodes limitation?
I am using Freecad version 0.18 for Windows on a HP Z440 workstation (Intel Xeon CPU E5-1650 v4 @y 3.60GHz,3601 MHz, 6 cores, 12 logical processor – 64Gb RAM)
Thanks in advance for your feedback,
Jonathan
Re: Number of nodes limitation - Calculix error 201
Postby Kunda1 » Tue Oct 22, 2019 12:45 pm
Please always post you Help > About FreeCAD > Copy to clipboard
Per recommended guidelines for FEM, please test this in the FC development version 0.19.x
You can get it from https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
Postby Kunda1 » Tue Oct 22, 2019 7:53 pm
Sorry, forgot to welcome you to the forum. ;)
Jckcdt
Postby Jckcdt » Wed Oct 23, 2019 8:11 am
I tried the V0.19, but still have the same problem : Calculix crashing when I exceed 350.000 nodes :
Writing CalculiX input file completed.
Run CalculiX ...
OverflowError
CalculiX failed with exit code 3221225477
Do you have any idea where it comes from ?
Thanks
Jonathan
bernd
Postby bernd » Wed Oct 23, 2019 8:15 am
I can confirm this for:
OS: Windows 10 (10.0)
Version: 0.19.18524 (Git)
Hash: bea009c1d52b97655dab2d5c0fbddec30989a902
Python version: 3.6.8
Qt version: 5.12.1
Locale: German/Switzerland (de_CH)
It is easy to test, just use 3D cantilever from start wb and make a fine mesh with 50 mm maximal element size.
which has ccx 2.15 preinstalled. But I do not know where this version comes from.
I will give it a try on Linux too. Next to try is if ccx gives the same error if run standalone with the inp file. Than it would be a ccx problem not a FreeCAD problem.
Jckcdt
Postby Jckcdt » Wed Oct 23, 2019 8:18 am
Thanks !
Jckcdt
Postby Jckcdt » Wed Oct 23, 2019 11:38 am
Qt version: 5.12.1
Same with
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
Locale: French/Belgium (fr_BE)
UR_
Postby UR_ » Wed Oct 23, 2019 1:56 pm
tested 3D-cantilever example from FreeCAD's start page
Remeshed netgen 50 mm, fine
========================== Dump contents of mesh ==========================
1) Total number of nodes:      	461377
2) Total number of edges:      	800
3) Total number of faces:      	31368
4) Total number of polygons:   	0
5) Total number of volumes:    	321238
6) Total number of polyhedrons:	0
7) Total number of linear edges:	0
8) Total number of linear faces:	0
9) Total number of linear volumes:	0
10) Total number of quadratic edges:	800
11) Total number of quadratic faces:	31368
11.1) Number of quadratic triangles:  	31368
11.2) Number of quadratic quadrangles:	0
12) Total number of quadratic volumes:	321238
12.1) Number of quadratic hexahedrons: 	0
12.2) Number of quadratic tetrahedrons:	321238
12.3) Number of quadratic prisms:      	0
12.4) Number of quadratic pyramids:    	0
version: (conda build)
Version: 0.19.18606 (Git)
Hash: 7222b32cdeae078305d319ef11b6574e701372a0
Python version: 3.7.3
Qt version: 5.12.5
used ccx build:
ccx_2.15_pardiso_dynamic.dhondt.exe from http://www.dhondt.de/
running as FreeCAD's subprocess
mkl libs from conda
memory footprint:
16 GB RAM + 16 GB page file
Screenshot 002.png (113.26 KiB) Viewed 766 times
bernd
Postby bernd » Wed Oct 23, 2019 3:05 pm
used ccx build:
These ones http://www.dhondt.de/calculix_2.15_4win.zip ?
UR_
Postby UR_ » Wed Oct 23, 2019 3:51 pm
These ones
yes ;)
