Assembly4: XLink absolute filepath problem
aapo
Re: Assembly4: XLink absolute filepath problem
Postby aapo » Fri Nov 08, 2019 8:07 am
realthunder wrote:
Fri Nov 08, 2019 12:09 am
It got stuck in one of my feature branch. I have just split it out and submitted the PR here.
After this patch will be applied, will it be possible to load old Assembly4 files containing absolute filepaths; or will there be a need to convert the files somehow?
Reading the code in the patch leads me to think, that if it's possible to read an old FCStd file, then saving the file with the patch enabed should make the xlink paths relative. Thus, I'd think that a simple load and save would make any Assembly4 files "good", but is this true?
realthunder
Postby realthunder » Fri Nov 08, 2019 11:05 pm
Yes, just load and save. You may need to manually save all the linked documents, because they are not marked as changed. Just set each document as active, and save.
FCuser2019
Postby FCuser2019 » Mon Nov 11, 2019 8:51 pm
adrianinsaval wrote:
Thu Nov 07, 2019 9:51 pm
Sorry to bother you but are there any news on this front?
Thanks for this fix, FreeCAD_0.19-18714 works :)
