OCE 0.18 -> OCCT 7.4.0: Crap ton of namespace issues
hobbes1069
Postby hobbes1069 » Thu Oct 31, 2019 1:13 am
Since OCE appears to be no longer maintained with OCCT's change to a FOSS license I'm working on moving FreeCAD on Fedora from OCE to OCCT but ran into some weird issues.
After switching from OCE to OCCT and removing netgen-mesher (since it doesn't build with current OCCT) I've started getting a ton of errors like this:
In file included from /builddir/build/BUILD/FreeCAD-0.18.3/src/3rdParty/salomesmesh/src/MEFISTO2/aptrte.cpp:27:
/builddir/build/BUILD/FreeCAD-0.18.3/src/3rdParty/salomesmesh/inc/Rn.h:183:10: error: 'istream' does not name a type
  183 |   friend istream& operator >>(istream& f,  R4 & P)
/builddir/build/BUILD/FreeCAD-0.18.3/src/3rdParty/salomesmesh/inc/Rn.h:188:10: error: 'istream' does not name a type
  188 |   friend istream& operator >>(istream& f,  R4 * P)
For both istream, ofstream, endl, etc. Patching to "std::<function>" for all instances fixes it but why is this necessary? Why would changing from OCE to OCCT affect namespace?
I also got a linker error that looks to be opengl related... weird.
Anyone know what the heck is going on?
Fedora Rawhide (f32)
gcc 9.2.1.
Thanks,
Richard
kkremitzki
Re: OCE 0.18 -> OCCT 7.4.0: Crap ton of namespace issues
Postby kkremitzki » Thu Oct 31, 2019 1:34 am
It's actually an OCCT 7.3.0 -> 7.4.0 change: https://www.opencascade.com/doc/occt-7. ... dnamespace
I encountered some resistance working on the aforementioned upgrade myself and haven't gotten the Debian/Ubuntu packaging updated for it yet. You would have better luck if you could use 7.3.0 for the time being.
Site Admin
Postby wmayer » Thu Oct 31, 2019 9:47 am
tanderson69
Postby tanderson69 » Thu Oct 31, 2019 1:35 pm
occt had some 'using' declarations in a header file. A 'no no'. These were carrying over to any project including it. They have since fixed this and any project that has accidentally took advantage of this will have to be fixed.
http://git.dev.opencascade.org/gitweb/? ... 2dc6001812
hobbes1069
Postby hobbes1069 » Fri Nov 01, 2019 11:39 am
Unless it's been fixed in master I probably should submit my patch for fixing all the namespace issues. Also, I got my linker problem sorted.
I was using:
-DOpenGL_GL_PREFERENCE=GLVND
and getting away with it due to transitive linking of libGL with OCE, but when I switched to OpenCASCADE apparently I wasn't getting it for free anymore.
After hitting my head against the wall and patching freecad to link with libGLU or libGL and getting the same error I tried changing the CMake option to
-DOpenGL_GL_PREFERENCE=LEGACY
No problems after that but it would probably be a good idea for FreeCAD to use the GL Vendor Neutral path at some point.
Thanks,
Richard
nahshon
Postby nahshon » Wed Nov 06, 2019 6:04 pm
Are there any pre-compiled RPMS for OCCT? I would like to try them with Fedora 31.
hobbes1069
Postby hobbes1069 » Wed Nov 06, 2019 9:44 pm
I just recently got them built and they are not yet in stable. I was going to push them with FreeCAD 0.18.4 which I just built today.
If you want to pull them manually you can get them from koji:
https://koji.fedoraproject.org/koji/pac ... geID=30181
Thanks,
Richard
nahshon
Postby nahshon » Thu Nov 07, 2019 2:16 am
Thanks! I installed these RPMS in Fedora 31 running under VirtualBox. I Could compile and start FreeCAD 0.19 (latest from GitHub).
Since git commit a7d9661b1d FreeCAD failed to compile with OCE on Fedora because Standard_Handle.hxx was missing. Installing OCCT fixed the issue for me.
DeepSOIC
Postby DeepSOIC » Thu Nov 07, 2019 10:13 am
They are using namespace::identifier, not using namespace. I can't seem to find anyone say it's a no-no, they usually say it is actually the only good way of using using.
https://akrzemi1.wordpress.com/2019/03/ ... space-std/ for example.
So, why is it bad?
tanderson69
Postby tanderson69 » Thu Nov 07, 2019 1:03 pm
So, why is it bad?
The blog you linked to is about 'using directives' vs 'using declarations' and kind of glosses over headers vs source files. Stack overflow is a good place for this kind of information.
https://stackoverflow.com/questions/584 ... -c-headers
