making finishing paths more efficient?
falviani
Postby falviani » Fri Nov 01, 2019 8:05 pm
Hi all,
I have a few projects in mind where I'd like to have a roughing pass with a largish cutter (up to 1/4") and then finish with a small cutter (around 1mm). As an experiment I put together a quick test where there was a large pocket in the model and then a couple of small blocks extruded from the pocket bottom 1.1 mm apart. When I did a roughing pass with a 3mm endmill then a finishing pass with a 1mm endmill (to cut between the blocks) the finishing pass processed the entire area already cut with the 3mm endmill. In other words, a tremendous waste of time. Is there a way I could have restricted the finishing pass?
I believe in Fusion 360 (which I use occasionally) a path can have a 'rest' attribute, which causes it to ignore areas that have already been processed. I'm looking for something equivalent, even if I have to do some manual masking.
Thanks in advance,
Frank
Re: making finishing paths more efficient?
Postby chrisb » Fri Nov 01, 2019 11:08 pm
You can reduce the StartDepth. I usually edit the expression and subtract the amount I want to skip.
falviani
Postby falviani » Mon Nov 04, 2019 8:45 pm
It's not so much the depth as avoiding entire areas. Consider milling a sign - the roughing cutter won't be able to cut between letters (and only roughly around those letters), and I want a finish pass to ONLY cut between letters and refine their shapes.
Postby chrisb » Mon Nov 04, 2019 8:57 pm
Ah, that's something different. Have a look at https://forum.freecadweb.org/viewtopic.php?f=15&t=40399.
herbk
Postby herbk » Mon Nov 04, 2019 9:13 pm
If i need this, i use a little workaround:
If i work with an 3mm endmill, i use a toolcontroller for a 3,2mm endmill for the first work, what lefts 0,1mm material.
For the finish path i use the 3mm toolcontroller and a contour OP to remove the rest.
Gruß Herbert
