Attached you'll find a drawing of a rather basic part that I made with TechDraw in FreeCAD 0.19.18640. However, if I open the FCStd file containing the drawing with FreeCAD 0.19.18640 or 0.19.18671, I'll get a hard crash with no error messages (FreeCAD just closes), apparently at that point when FreeCAD tries to load the TechDraw page. The weird thing is that I can open the file (and the TechDraw drawing inside it) with FreeCAD 0.19.18504 just fine, even though it was saved with a more recent version. In other words, the more recent FreeCAD 0.19.18640 dies when trying to open a file saved with itself, while the older versions are fine with the offending file!
TLDR: The included .FCStd file causes a hard crash on load for me for any recent FreeCAD version.
OS: Windows 10 (10.0)
Version: 0.19.18671 (Git)
Hash: 5476ab4b61fed05d37aae3a01ecd2e62d6d54200
Python version: 3.6.7
Qt version: 5.12.1
Version: 0.19.18640 (Git)
Hash: 2251f53eb5af097cbb4b879af89575132660e541
Qt version: 5.12.1
Version: 0.19.18504 (Git)
Hash: f66023a646db4b2502bb3637897443b3525ca3c7
Python version: 3.6.8
Qt version: 5.12.1
EDIT: With a Linux machine I get the following crash when opening the file with v 0.19.18676. It seems to be related to the CenterLine loading and recomputing, even though in this case all the CenterLines should be "alive".
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3a100) [0x7f4d17643100]
#1 0x7f4ca634df3a in opencascade::handle<TopoDS_TShape>::IsNull() const from /home/alankine/software/freecad-build/Mod/TechDraw/TechDraw.so+0xc
#2 0x7f4ca6344e54 in TopoDS_Shape::IsNull() const from /home/alankine/software/freecad-build/Mod/TechDraw/TechDraw.so+0x18
#3 0x7f4ca643cf12 in TechDraw::BaseGeom::findEndPoints() from /home/alankine/software/freecad-build/Mod/TechDraw/TechDraw.so+0x3c
#4 0x7f4ca643d148 in TechDraw::BaseGeom::getStartPoint() from /home/alankine/software/freecad-build/Mod/TechDraw/TechDraw.so+0x24
#5 0x7f4ca6457466 in TechDraw::CenterLine::calcEndPoints2Lines(TechDraw::DrawViewPart*, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, int, double, double, double, double, bool) from /home/alankine/software/freecad-build/Mod/TechDraw/TechDraw.so+0x27a
#6 0x7f4ca6455dd2 in TechDraw::CenterLine::scaledGeometry(TechDraw::DrawViewPart*) from /home/alankine/software/freecad-build/Mod/TechDraw/TechDraw.so+0x2b0
#7 0x7f4ca63d7e76 in TechDraw::DrawViewPart::addCenterLinesToGeom() from /home/alankine/software/freecad-build/Mod/TechDraw/TechDraw.so+0x76
#8 0x7f4ca642d67b in TechDraw::DrawViewDetail::execute() from /home/alankine/software/freecad-build/Mod/TechDraw/TechDraw.so+0x1455
#9 0x7f4d19ce3d02 in App::DocumentObject::recompute() from /home/alankine/software/freecad-build/lib/libFreeCADApp.so+0xc2
#10 0x7f4d19c0a497 in App::Document::_recomputeFeature(App::DocumentObject*) from /home/alankine/software/freecad-build/lib/libFreeCADApp.so+0x1b5
#11 0x7f4d19c0b288 in App::Document::recomputeFeature(App::DocumentObject*, bool) from /home/alankine/software/freecad-build/lib/libFreeCADApp.so+0xf8
#12 0x7f4d19ce3e85 in App::DocumentObject::recomputeFeature(bool) from /home/alankine/software/freecad-build/lib/libFreeCADApp.so+0x3f
#13 0x7f4ca63d85dd in TechDraw::DrawViewPart::onDocumentRestored() from /home/alankine/software/freecad-build/Mod/TechDraw/TechDraw.so+0x1d
#14 0x7f4d19c04198 in App::Document::afterRestore(std::vector<App::DocumentObject*, std::allocator<App::DocumentObject*> > const&, bool) from /home/alankine/software/freecad-build/lib/libFreeCADApp.so+0x600
#15 0x7f4d19c03975 in App::Document::afterRestore(bool) from /home/alankine/software/freecad-build/lib/libFreeCADApp.so+0x5d
#16 0x7f4d19eb6213 in App::Application::openDocuments(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const*, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const*, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) from /home/alankine/software/freecad-build/lib/libFreeCADApp.so+0x6e7
#17 0x7f4d19eb5a87 in App::Application::openDocument(char const*, bool) from /home/alankine/software/freecad-build/lib/libFreeCADApp.so+0xc5
#18 0x7f4d19ee6515 in App::Application::sOpenDocument(_object*, _object*, _object*) from /home/alankine/software/freecad-build/lib/libFreeCADApp.so+0xe3
#19 /usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0(_PyMethodDef_RawFastCallKeywords+0x2db) [0x7f4d18db532b]
#20 /usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0(_PyCFunction_FastCallKeywords+0x28) [0x7f4d18db5c78]
#21 /usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0(+0x6e250) [0x7f4d18bc6250]
#22 /usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0(_PyEval_EvalFrameDefault+0x68a2) [0x7f4d18bccc42]
#23 /usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0(_PyEval_EvalCodeWithName+0x92d) [0x7f4d18cee61d]
#24 /usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0(PyEval_EvalCodeEx+0x3e) [0x7f4d18ceda2e]
#25 /usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0(PyEval_EvalCode+0x1b) [0x7f4d18cef07b]
#26 /usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0(PyRun_StringFlags+0x8f) [0x7f4d18cbdeef]
#27 0x7f4d19219b7c in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /home/alankine/software/freecad-build/lib/libFreeCADBase.so+0xd8
#28 0x7f4d1b1332a8 in Gui::Command::_runCommand(char const*, int, Gui::Command::DoCmd_Type, char const*) from /home/alankine/software/freecad-build/lib/libFreeCADGui.so+0xca
#29 0x7f4d1b132f76 in Gui::Command::_doCommand(char const*, int, Gui::Command::DoCmd_Type, char const*, ...) from /home/alankine/software/freecad-build/lib/libFreeCADGui.so+0x112
#30 0x7f4d1afe0b27 in Gui::Application::open(char const*, char const*) from /home/alankine/software/freecad-build/lib/libFreeCADGui.so+0x257
#31 0x7f4d1b14813a in StdCmdOpen::activated(int) from /home/alankine/software/freecad-build/lib/libFreeCADGui.so+0x84a
#32 0x7f4d1b131ee7 in Gui::Command::invoke(int, Gui::Command::TriggerSource) from /home/alankine/software/freecad-build/lib/libFreeCADGui.so+0x313
#33 0x7f4d1b1245da in Gui::Action::onActivated() from /home/alankine/software/freecad-build/lib/libFreeCADGui.so+0x26
#34 /home/alankine/software/freecad-build/lib/libFreeCADGui.so(+0xf596c3) [0x7f4d1b1296c3]
#35 0x7f4d17c633c8 in QMetaObject::activate(QObject*, int, int, void**) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x7b8
#36 0x7f4d1862e812 in QAction::triggered(bool) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x42
#37 0x7f4d18630e52 in QAction::activate(QAction::ActionEvent) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x102
#38 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x2df522) [0x7f4d187b2522]
#39 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x2e6baa) [0x7f4d187b9baa]
#40 0x7f4d187babd2 in QMenu::mouseReleaseEvent(QMouseEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x272
#41 0x7f4d18676786 in QWidget::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x246
#42 0x7f4d187bd1b3 in QMenu::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x153
#43 0x7f4d18634c32 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x82
#44 0x7f4d1863e3e3 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x583
#45 0x7f4d1b0f911d in Gui::GUIApplication::notify(QObject*, QEvent*) from /home/alankine/software/freecad-build/lib/libFreeCADGui.so+0xff
#46 0x7f4d17c38a92 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x182
#47 0x7f4d1863d4f3 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x1b3
#48 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x1bf9d4) [0x7f4d186929d4]
#49 /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x1c1ed4) [0x7f4d18694ed4]
#50 0x7f4d18634c32 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x82
#51 0x7f4d1863e190 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5+0x330
#52 0x7f4d1b0f911d in Gui::GUIApplication::notify(QObject*, QEvent*) from /home/alankine/software/freecad-build/lib/libFreeCADGui.so+0xff
#53 0x7f4d17c38a92 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x182
#54 0x7f4d18016a33 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5+0x6c3
#55 0x7f4d1801828b in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5+0x24b
#56 0x7f4d17ff2eeb in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5+0xbb
#57 /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5(+0x71d0a) [0x7f4d11ef7d0a]
#58 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x27d) [0x7f4d15b53ead]
#59 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x50130) [0x7f4d15b54130]
#60 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2f) [0x7f4d15b541bf]
#61 0x7f4d17c8e7f1 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x61
#62 0x7f4d17c3771b in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x12b
#63 0x7f4d17c3f1c2 in QCoreApplication::exec() from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5+0x92
#64 0x7f4d1afe9e81 in Gui::Application::runApplication() from /home/alankine/software/freecad-build/lib/libFreeCADGui.so+0x23b1
#65 bin/FreeCAD(main+0xb1e) [0x55c76b8e9158]
#66 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb) [0x7f4d1762fbbb]
#67 bin/FreeCAD(_start+0x2a) [0x55c76b8e84ca]
OS: Debian GNU/Linux bullseye/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.18676 (Git)
Build type: Unknown
Hash: 0347a4b7a61ae3af46ec8f6aac256efdc5b4bcb8
Python version: 3.7.5rc1
Qt version: 5.11.3
