[FIXED] Allowed section area smaller than Body size
aapo
Postby aapo » Thu Nov 07, 2019 5:32 pm
Hi!
I noticed a small problem with TechDraw sections. It's a bit difficult to explain, so I made video about the problem. Basically the section view cannot extend beyond the body's original bounding box, and if you rotate the body, the bounding box is not rotated, which generally gives you too tight limits for the section line positions. Sorry about the bad quality in the video, but the forum won't allow files over 1 MB.
The following error is displayed, even though the section definitely intersects the part:
DVS: SectionOrigin doesn't intersect part in DrawViewSection
DVS: Using center of bounding box.
EDIT: I forgot to attach the FCStd file, but it should be attached now. In the file, there is a section, which has origin (5,5,10). If you'll try to increase the z-value to 11, it jumps to 5 (the center of the original bounding box), even though there would clearly be room to increase the z-coordinate of the origin to 14.1... Anything bigger than 10, which is the z-coordinate of the original bounding box, resets the value to the center.
OS: Debian GNU/Linux bullseye/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.18696 (Git)
Build type: Unknown
Hash: dd120ef5075353580090dd385c235b4c74433745
Python version: 3.7.5
Qt version: 5.12.5
20191107_FreeCAD_TechDraw_section.FCStd
(22.62 KiB) Downloaded 6 times
wandererfan
Re: [Bug?] Allowed section area smaller than Body size
Postby wandererfan » Fri Nov 08, 2019 5:43 pm
I think this is due to the Base view being in a ProjectionGroup. The RotationVector isn't handle properly in Section. Regular views don't have a RotationVector. If I position a regular View in the same way with Placement, the section looks right.
I'm going to remove the second half of that warning and the code that changes the SectionOrigin. If the user wants a SectionPlane that doesn't cut anything, so be it. I'll leave in the part that points out the lack of intersection.
aapo
Postby aapo » Fri Nov 08, 2019 11:29 pm
That's a good plan, I think. However, I wonder if it could be possible to reset the SectionOrigin in the case, where there are no edges/faces found at all after the algorithm has run? I mean an empty set of edges in the section view would be quite a certain sign that the SectionOrigin is at a place where it should not be.
aapo
Postby aapo » Wed Nov 27, 2019 10:10 pm
Now it works with the current master, which has your latest pull request applied, thanks!
Version: 0.19.18801 (Git)
Build type: Unknown
Hash: 2efd9a133ec69be63aa45f6d87e7e1c3ec04cd64
Qt version: 5.12.5
