[FIXED] Section is missing edges for some section directions in FreeCAD TechDraw
aapo
Postby aapo » Fri Nov 08, 2019 1:13 pm
Hi again!
This time I stumbled upon TechDraw section missing some edges in the cut surface, but only for some of the possible section directions. I made a simple body (attached), which is a hollow cube, with a sphere cut out from the center. The shape should be perfectly symmetrical in respect to the main axes x, y, and z. The expected section cuts should all be squares with a circle in the center. However, the up and down direction sections are missing the dimensionable circle edge and the arc center mark, even though the section cuts look correct otherwise. I have the same problem with other shapes, too, and as a workaround I only make left or right section cuts, and rotate the parts accordingly - which is a bit cumbersome. I have the same problem with both Windows and Linux versions.
OS: Windows 10 (10.0)
Version: 0.19.18671 (Git)
Hash: 5476ab4b61fed05d37aae3a01ecd2e62d6d54200
Python version: 3.6.7
Qt version: 5.12.1
OS: Debian GNU/Linux bullseye/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.18702 (Git)
Build type: Unknown
Hash: aab61f3e151e65975e370b4d8ff3611d6355730c
Python version: 3.7.5
Qt version: 5.12.5
20191108-TechDraw-section-missing-line.FCStd
(25.61 KiB) Downloaded 13 times
wandererfan
Re: [Bug?] Section is missing edges for some section directions in FreeCAD TechDraw
Postby wandererfan » Fri Nov 08, 2019 5:27 pm
Thanks for reporting!
I'm working with @bitacovir on Sections right now. The current development version handles your case correctly.
Still a few section issues to work out.
wandererfan
Postby wandererfan » Fri Nov 08, 2019 5:31 pm
and the other 2 directions for completeness....
aapo
Postby aapo » Fri Nov 08, 2019 11:22 pm
Nice to hear, thanks! It seems that the TechDraw in v0.19 is going to be much better than the one in v0.18. Can't wait! :D
aapo
Postby aapo » Wed Nov 27, 2019 10:17 pm
Thanks for the fix, I can confirm that this also works as expected with the latest master build (versions > 0.19.18800). Great work! :D
Version: 0.19.18801 (Git)
Build type: Unknown
Hash: 2efd9a133ec69be63aa45f6d87e7e1c3ec04cd64
Qt version: 5.12.5
