Thanks for posting the Report View - it seems I introduced a cyclic dependency which causes the error. The reason I didn't notice is because the dependency is broken if the Path workbench is the workbench being loaded on startup - which is typically the case for me.
So as a workaround, until I get the fix in, try loading the Path workbench first and then open the file with a Path.
EDIT: PR-2709
