Cannot edit job after saving
mlampert
Re: Cannot edit job after saving
Postby mlampert » Mon Nov 11, 2019 1:07 am
Thanks for posting the Report View - it seems I introduced a cyclic dependency which causes the error. The reason I didn't notice is because the dependency is broken if the Path workbench is the workbench being loaded on startup - which is typically the case for me.
So as a workaround, until I get the fix in, try loading the Path workbench first and then open the file with a Path.
EDIT: PR-2709
masterchippy
Postby masterchippy » Mon Nov 11, 2019 7:23 am
Thank you will give that a try. regards
Jamie
Worked for me :D
