[Solved] Rename: Draft_Edit_Improved to Draft_SubelementHighlight
vocx
Post by vocx »
The Draft_Edit_Improved page should be renamed to Draft_SubelementHighlight.
This command was previously called Draft_Edit_Improved, but after further consideration, and to avoid confusion, it was decided to rename it first to Draft_SubelementModify, and now to Draft_SubelementHighlight.
See pull request #2597 and #2705. The original tool comes from pull request #1975, and Proposal for draft modifiers to work in draft edit mode.
https://github.com/FreeCAD/FreeCAD/blob ... s.py#L5688
FreeCADGui.addCommand('Draft_SubelementHighlight', SubelementHighlight())
Reason: Added [Solved] to thread title
Re: Rename: Draft_Edit_Improved to Draft_SubelementHighlight
Post by Kunda1 »
Moved but concernably it didn't auto redirect the old pages to the new one. I had to manually redirect the main English page. Does this need to be done for the translation pages as well?
