Convert mesh to shape
xyz3D
Postby xyz3D » Wed Nov 13, 2019 5:26 pm
This simple script convert a mesh from a command line into a shape. The output formats are those of FreeCAD STEP, IGES, STL and BREP.
It is possible to enable Refine Shape and Make Solid with an option from the command line.
#!/usr/bin/env python3
FREECAD_PATH = '/usr/lib/freecad-python3/lib'
#FREECAD_PATH = '/opt/freecad/lib'
import site
site.addsitedir(FREECAD_PATH)
import os
import sys
import argparse
import FreeCAD
import Mesh
import Part
PROG_NAME = os.path.basename(os.path.splitext(sys.argv[0])[0])
PROG_VERSION = '1.0'
DEFAULT_TOLERANCE = 0.05
def main():
    parser = argparse.ArgumentParser(
        description=PROG_NAME + ' V' + PROG_VERSION)
    parser.add_argument(
        '-V',
        '--version',
        action='version',
        version='%(prog)s V' + PROG_VERSION,
        help='display the version number')
        '-r',
        '--refine-shape',
        action='store_true',
        default=False,
        help='enable refine shape')
        '-s',
        '--make-solid',
        default=False,
        help='enable make solid')
        '-t',
        '--tolerance',
        type=float,
        action='store',
        default=DEFAULT_TOLERANCE,
        metavar='VALUE',
        help='the tolerance for sewing (default VALUE={})'
        .format(DEFAULT_TOLERANCE))
        'mesh_file',
        action='store',
        metavar='mesh.ext',
        default=None,
        help='mesh input file')
        'shape_file',
        action='store',
        metavar='shape.ext',
        default=None,
        help='shape output file')
    args = parser.parse_args()
    refine_shape = args.refine_shape
    make_solid = args.make_solid
    tolerance = args.tolerance
    mesh_file = args.mesh_file
    shape_file = args.shape_file
    (_, ext) = os.path.splitext(shape_file)
    if not ext:
        raise RuntimeError(
            'filename\'s extension is missing, filename: "{}"'.format(
                shape_file))
    ext = ext.lower()
    # import
    mesh = Mesh.Mesh()
    mesh.read(mesh_file)
    # convert mesh to shape
    shape = Part.Shape()
    shape.makeShapeFromMesh(mesh.Topology, tolerance)
    # Refine shape
    if refine_shape:
        shape = shape.removeSplitter()
    # Make solid
    if make_solid:
        shape = Part.makeSolid(shape)
    # exports to an STEP file
    if ext in ['.step', '.stp']:
        shape.exportStep(shape_file)
    # export to an IGES file
    elif ext in ['.iges', '.igs']:
        shape.exportIges(shape_file)
    # export to an STL file
    elif ext == '.stl':
        shape.exportStl(shape_file)
    # export to an BREP file
    elif ext in ['.brep', '.brp']:
        shape.exportBrep(shape_file)
    # unknown file extension
    else:
        raise RuntimeError('Unknown file extension: "{}"'.format(ext))
if __name__ == '__main__':
    main()
Site Admin
Re: Convert mesh to shape
Postby wmayer » Wed Nov 13, 2019 6:14 pm
The Shape class has the method removeSplitter() which does the refinement.
Postby chrisb » Wed Nov 13, 2019 6:46 pm
Thanks for sharing. Usually we get every now and then an invalid mesh, but now I have none at hand. So I don't know what happens with such a mesh. Is it possible to apply with another commandline switch a CheckGeometry on the result?
openBrain
Postby openBrain » Wed Nov 13, 2019 6:47 pm
I think you believe that was a question but that actually was a statement from OP. It is already implemented. ;)
