Hi
Unfortunately my english is very bad. That's why I asked google to translate it for me. I just wanted to show you in a few pictures what I created in A2 +. I would be happy if AMS3 is done. That I can turn the engine.
Greetings from Germany
Dirk
Taifun Bison from 1970
- Taifun- Bison-1970-05.JPG (41.85 KiB) Viewed 2775 times
- Taifun- Bison-1970-04.JPG (22.98 KiB) Viewed 2775 times
- Taifun- Bison-1970-03.JPG (23.69 KiB) Viewed 2775 times
- Taifun- Bison-1970-02.JPG (21.85 KiB) Viewed 2775 times
- Taifun- Bison-1970-01.JPG (24.02 KiB) Viewed 2775 times
Re: Taifun Bison from 1970
Nice modeling Dirk.
Really nice work, Dirk. Can you:
- elaborate more about the history of this model?
- What version of FC you used?
- What version of A2+ you used?
- How long did it take you to model?
- What were issues you encountered and workarounds you used?
- Explain why you didn't animate the model? (since A2+ has that capability)
Good model Dirk.
@Kunda1 :-
Explain why you didn't animate the model? (since A2+ has that capability):-
I do not find any thread for animation capability of A2+, if you can share any thread or link for A2+ animation, that will be great help.
Thanks.
@Kunda1 :-
Thanks.
It's possible to animate assemblies in A2plus using Python scripting, see https://forum.freecadweb.org/viewtopic. ... 7&p=309646 (perhaps asking on that thread would be more relevant for the specifics on how to do so)
Hello
I found the model engine in my workshop. It belonged to my father who had it in a model airplane. I had no CAD experience and started in Feb 2019 with FreeCad. I found it a good idea to draw the engine for practice.
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Since then I get the error message.Constraints inconsistent.at the following parts.Haven't found a solution here.
and I don't know my way around Python.
Many greetings
Dirk
OS: Windows 10What version of FC you used?
Qt version: 5.6.2
A2plus V0.3.1What version of A2+ you used?
It took me about 100 h to draw the components, and about 10 h to assemble them in A2+.How long did it take you to model?
I had problems with parts that were rounded. Here A2+ did not find any covers so that I drew the part for example (throttle lever) without roundings. With the jet needle which consists of three bodies I found also no clear Pos. To bring the carburettor on Posision I succeeded only by the alignment of the axial bore.What were issues you encountered and workarounds you used?
Unfortunately I don't know the possibility of animation in A2 +Explain why you didn't animate the model? (since A2+ has that capability)
Many greetings
Dirk
- MotorTrans.JPG (214.74 KiB) Viewed 2271 times
- Fehlermeldung.JPG (19.28 KiB) Viewed 2279 times
- Düsennadel.JPG (85.69 KiB) Viewed 2279 times
