Machine speed gcode not generated correctly
falviani
Re: Machine speed gcode not generated correctly
Postby falviani » Sat Nov 23, 2019 4:06 am
I thought I did - must be having a senior moment. I'll upload it in the morning. Sorry.
falviani
Postby falviani » Sat Nov 23, 2019 1:30 pm
Here's the project that demonstrates the problem I found. Sorry for not uploading it before :(
Frank
FlushTwice_v3.FCStd
(614.68 KiB) Downloaded 10 times
Postby chrisb » Sat Nov 23, 2019 7:05 pm
I see now what you mean. You expect "split output" to create self contained jobs. Instead it just splits the output for small machines, which cannot load huge jobs at once (well usually they are big with small memory, like a former colleague of mine). It may be sensible to have such an option, but to me this looks rather like three separate jobs.
sliptonic and mlampert may judge this.
If you use the first job as template, then you are almost as fast creating those as if the operations live all in the same job.
falviani
Postby falviani » Sat Nov 23, 2019 9:48 pm
I see. I'd get the desired result if I created a job and the first operation, a 2nd job and operation, and a 3rd job and operation. I just did a quick experiment, and just copying the job doesn't seem to do what I want, but creating new jobs/operations isn't a huge deal for now. After all the jobs, I can just post process each in turn.
mlampert
Postby mlampert » Sat Nov 23, 2019 11:33 pm
I'm not familiar with the coordinate splitting - not sure if this is a bug or a feature. I see what you are trying to do and would follow Chris' recommendation and splitting this into 3 jobs. Note that when you create a new Job you can select an existing Job as its "Model" - in which case the second job gets the same base objects in the same position/orientation - in other words it uses the same setup.
Postby chrisb » Sun Nov 24, 2019 1:04 am
Sadly it doesn't use the same tools, and it doesn't use the same output.
mlampert
Postby mlampert » Sun Nov 24, 2019 2:06 am
It does if you use the same template ;)
The idea here was that you want different tools - why else would you want multiple jobs with the same setup? This is the very poor man's version of a tool changer :mrgreen:
Postby chrisb » Sun Nov 24, 2019 7:51 am
You are right, and it makes sense. I had just tried to follow OP's use case and thought it would suffice to reuse the job. So there is one question left, which I forgot to ask explicitely: What is the use case of this split? Could a stop between the operations be enough?
falviani
Postby falviani » Sun Nov 24, 2019 2:56 pm
Since I was having trouble with the engrave operation (I'll explain that shortly) I decided to use the profile edges operation, and select the edges of each letter manually. I selected the interior of each letter and created a pocket so I had selectable edges. Now that I had edges, that was resulting in a huge list, so I broke it into groups, 1 per word, to make it manageable.
Engrave operation problem: I created a shapestring in the draft workbench, and used the 'convert between draft and sketch objects' to create a sketch that could be selected when creating the engrave toolpath. However, I get an error: 'Document.cpp (3462): Failed to recompute unnamed engrave: Part.BSplineObject has no attribute 'Axis' so I am stuck.
By the way, I can't copy text out of the report view :(
I hope this clarifies why I did what I did.
Thanks for your help and advice,
Frank
Postby chrisb » Sun Nov 24, 2019 4:40 pm
I can perfectly understand the difficulties in creating the paths, but once you get them, you can mill them in one go.
The question is, why you generate three files, i.e. why did you check in Job->Output the Split output box.
