Small single-family house made of foam concrete.
rmavrichev
Postby rmavrichev » Tue Dec 03, 2019 9:33 pm
My project of the small single-family house made of foam concrete.
https://github.com/rmavrichev/freecad-p ... _8500x9500
small_one_family_house_built_from foam_concrete.png (739.79 KiB) Viewed 2737 times
отопление и вентиляция.png (418.89 KiB) Viewed 2737 times
thschrader
Re: Small single-family house made of foam concrete.
Postby thschrader » Wed Dec 04, 2019 1:17 pm
Downloaded your file, excellent work!
rmavrichev
Postby rmavrichev » Wed Dec 04, 2019 2:52 pm
Thanks! These are my first steps in freecad. But I had some experience with autocad and varicad.
bitacovir
Postby bitacovir » Wed Dec 04, 2019 11:03 pm
Good work.
If you built it, show some pictures.
::bitacovir::
My Blog
Mini Airflow Tunnel Project
carlopav
Postby carlopav » Thu Dec 05, 2019 2:58 pm
Very nice and tidy model.
How did you model the windows?
rmavrichev
Postby rmavrichev » Fri Dec 06, 2019 9:26 am
The model is not completed yet. But arch workbench have a good tool for creating windows.
I used this tool in my other project of the small bathhouse built of profiled logs.
https://github.com/rmavrichev/freecad-p ... m_wood.png
Willem
Postby Willem » Sun Dec 08, 2019 3:00 pm
I like this project, but 1 comment. I am afraid that when I am on top of the stairs I hit my head to the roof. My suggestion is to rotate the top of the stair 90 degrees to the middle of the house
rmavrichev
Postby rmavrichev » Mon Dec 09, 2019 5:21 pm
I made some changes to the improved version of the interior layout.
triplus
Postby triplus » Tue Dec 10, 2019 8:02 pm
Nice work!
Zolko
Postby Zolko » Wed Dec 11, 2019 10:29 am
In the bathroom, you have water coming from all 4 walls, and sewers going down on 3 walls, that's going to make a lot of plumbing. Especially the toilets are going to be a PITA. Can't you regroup the water supply and sewer needs into a more concentrated region (ideally 1 wall) ? And close to the needs with the kitchen ? Much less hassle to actually build.
