Cannot export sketch to DXF
chris s
Postby chris s » Sun Dec 22, 2019 2:57 pm
I am using Freecad 0.18 and I have checked the import/export dxf box that enables it to automatically download the DXF libraries.
Problem is when I then select to export a sketch it says techdraw module does not support that object type.
What am I doing wrong?
Roy_043
Re: Cannot export sketch to DXF
Postby Roy_043 » Sun Dec 22, 2019 3:13 pm
chris s
Postby chris s » Sun Dec 22, 2019 3:22 pm
I have not created an object, I have just used Freecad to create a 2d sketch which needs to be in DXF format.
Do I have to dreate an object?
Roy_043
Postby Roy_043 » Sun Dec 22, 2019 3:27 pm
If you align the view with your sketch and check the "Project exported objects along current view direction" exporting to DXF should work.
If not: post your file.
wandererfan
Postby wandererfan » Sun Dec 22, 2019 7:47 pm
Sounds like you are asking to export a "Technical Drawing".
You want to pick "Autodesk Dxf".
vocx
Postby vocx » Mon Dec 23, 2019 1:08 am
You have to explain each step that you are doing.
1. First open FreeCAD
2. Select the Sketcher Workbench.
3. Draw a sketch.
4. Select the Sketch, and use TechDraw NewView.
etc.
You need to describe your problem with all details. Otherwise people trying to help you can only guess what steps you are taking.
Also, see Std_About.
chris s
Postby chris s » Mon Dec 23, 2019 2:43 pm
I have a sketch on my tree which I select then file export, all the dxf options.
I now get an error message Export failed, invalid syntax dxfreader.py line 88
This happens both in sketcher workbench and techdraw.
Do I need to post you my file?
easyw-fc
Postby easyw-fc » Mon Dec 23, 2019 2:49 pm
That's it!
You need to update your dxf library through Addons manager
wandererfan
Postby wandererfan » Mon Dec 23, 2019 2:56 pm
Post your file. You'll get better answers and get them quicker.
TechDraw only exports drawing pages. If you're trying to export the Sketch directly, TD won't help.
Selecting a sketch in the tree, then File>Export> "AutoDesk Svg" works here.
Syres
Postby Syres » Mon Dec 23, 2019 4:09 pm
This is a long outstanding bug that still applies today for users upgrading from 0.16 to either 0.18 or 0.19. I've just tested the procedure on Windows and can confirm the bug still exists. I'll put a PR in for each branch as the importDXF.py has changed significantly over the past few months.
Edit: Two PR's logged https://github.com/FreeCAD/FreeCAD/pull/2813 and https://github.com/FreeCAD/FreeCAD/pull/2814
