[fixed] leader line disappears when reopening document
uwestoehr
Postby uwestoehr » Wed Jan 08, 2020 3:27 pm
I think there is a bug:
When creating a leader line, it is visible and shows the red color I want.
So this is what I designed:
as designed and desired
Then I close the document and reopen it:
FlyMiBird-Anpressplatte-gefraest.FCStd
FC file
(76.48 KiB) Downloaded 9 times
What I get is this:
after reopening
So the positions of the projections are wrong and also the leader line is no longer visible.
wandererfan
Re: leader line disappears when reopening document
Postby wandererfan » Wed Jan 08, 2020 4:05 pm
The second image looks like the views have been autodistributed. Is Autodistribute on for the ProjectionGroup?
I know about the leader line issue. You have to click it in the tree, then it appears. I've looked for the bug a few times, but no success yet. Probably staring right at it without seeing it.
uwestoehr
Postby uwestoehr » Wed Jan 08, 2020 4:42 pm
Stupid me. It was on by default. I am not sure if it should be on by default. if the ISO norms recommend or even request this then of course it should be on. I don't know the content of the norms, so maybe my drawing is not norm-conform?
OK.
A minor issue: in the tree view the auto-label is "DrawLeaderLine" shouldn't it just be "LeaderLine"?
wandererfan
Postby wandererfan » Thu Jan 09, 2020 12:48 am
As far as I know the First/Third angle conventions only address the arrangement of the orthogonal views. So a case could be made that the iso views shouldn't be autodistributed ever.
Probably. All those "Draw" prefixes are a legacy of when TechDraw was Drawing v2.0.
uwestoehr
Postby uwestoehr » Thu Jan 09, 2020 1:20 am
OK, so autodistribute could also be turned off by default. I vote for this since in Solidworks this is also off by default and I stumble over this regularily.
So we can get rid of them. I'll have a look the next days.
wandererfan
Postby wandererfan » Thu Jan 09, 2020 1:50 pm
Default for autodistribute can be changed in Preferences in "General" category.
uwestoehr
Postby uwestoehr » Thu Jan 09, 2020 11:24 pm
Thanks. I did not yet notice this.
Site Admin
Postby wmayer » Sat Jan 11, 2020 1:19 pm
Don't know if this is of any help for you. When loading the project file then relevant function calls are:
  1. MDIViewPage::attachView
  2. QGVPage::addViewLeader
  3. QGILeaderLine::updateView
  4. QGILeaderLine::draw
  5. QGIView::getGraphicsView
  6. ViewProviderDrawingView::getMDIViewPage
  7. ViewProviderPage::getMDIViewPage
Since the ViewProviderPage has no MDI view yet it returns null and its calling instances, too. That's why QGILeaderLine::draw then returns in the middle of the function, too.
If I disable this check (because it nowhere uses the "view" pointer) the leader line is at least shown in the MDI view, however at the wrong position. When selecting it then it jumps to the correct position.
The attachView function is called inside the constructor of MDIViewPage, i.e. before its assigned to the m_mdiView member of the ViewProviderPage. Maybe you should split the constructor into two parts:
leave the pure construction stuff in the constructor and move adding all items to a second function which you call from within ViewProviderPage::showMDIViewPage after the MDIViewPage is assigned to the m_mdiView.
wandererfan
Postby wandererfan » Sat Jan 11, 2020 2:26 pm
Thanks for the clues. I'll try your suggestions.
wf
wandererfan
Postby wandererfan » Sun Jan 12, 2020 11:44 pm
Thanks to @wmayer's hints, this should be fixed by git commit 00c69a9c64.
