Installing Dark Theme
usbhub
Postby usbhub » Fri Jan 17, 2020 9:09 pm
I hope I'm in the right subforum :?
I''m trying to install the dark theme, but I only find old threads (0.16 and older) about it. Is there any installation instruction for it on new versions? I found the information, that you can do it in the preferences, but I find nothing in my preferences menu…
Maybe a wiki article would be a good idea, maybe I'm not the only user with this problem.
Regards
usbhub
vocx
Re: Installing Dark Theme
Postby vocx » Sat Jan 18, 2020 12:03 am
...Is there any installation instruction for it on new versions?...
Important information
usbhub
Postby usbhub » Sun Jan 19, 2020 8:20 pm
I didn't name my special version, because that was more a general request about an installation "manual", so I didn't posted my version, but here is my:
OS: Linux Mint 19
Version: 0.18.4.
Python version: 2.7.15+
Qt version: 5.9.5
triplus
Postby triplus » Sun Jan 19, 2020 9:26 pm
Look under Edit -> Preferences ... -> General -> Style sheet. There should be a couple of FreeCAD themes listed there.
usbhub
Postby usbhub » Tue Jan 21, 2020 8:40 pm
Ah, I looked under Display :?
Maybe it would make sence to change that, because the theme is more part of the display I think.
triplus
Postby triplus » Tue Jan 21, 2020 10:46 pm
Good to hear you sorted it out.
Display section focuses more on the 3D viewport.
vocx
Postby vocx » Wed Jan 22, 2020 3:32 am
Qt version: 5.9.5
Python 2 is obsolete. You need to be using Python 3 with Qt 5.
Install the Python 3 version of FreeCAD.
triplus
Postby triplus » Thu Jan 23, 2020 9:53 pm
FreeCAD 0.18 is i guess still considered to be Py2/Py3 compatible. Therefore no special need to worry about it, as long as everything is working fine.
