Problem with negative offset "Placement" in Building US units
jylandry
Postby jylandry » Sun Jan 26, 2020 5:53 am
OS: Ubuntu 18.04.3 LTS
Version: 0.18.4.
Python version: 3.6.8
Qt version: 5.9.5
I have a problem to create a negative offset in the "Placement" function. This is not major issue... but that force me to work in different unit.
I operate with the unit preference in "Building US(ft-in/sqft/cuft)
In the Placement box --> translation: --> X: -- If I enter -1.5", it seems to work (drawing updated OK)... but when it get converted to fraction, it return -1/2" and the drawing is updated to the wrong value.
Still seem OK when "Apply Axial is click" -- Properly translated in Fraction. (Note: If I enter /// -1+1/2" /// , it create the problem right away at the "Apply Axial Click".
Clicking OK -- and then re-entering "Placement" just show the fraction being changed to /// -1/2" ///
wandererfan
Re: Problem with negative offset "Placement" in Building US units
Postby wandererfan » Sun Jan 26, 2020 9:55 pm
Problem is still here in freecad-daily:
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
Also happens with measurements like -13'6" becoming -12'6".
Glad you posted, I've been trying to figure out what I was doing wrong for a couple of days now.
arcanemachine
Postby arcanemachine » Mon Jan 27, 2020 1:43 am
I've always had problems with fractional units in FreeCAD (new user though).
I learned to format it as "1 in / 2" (hit the equals (=) button to use an Expression) and I've never had any problems after formatting it that way.
OS: Windows 8.1 (6.3)
Version: 0.19.19239 (Git)
Hash: 49e4e45ff38b0459f0f9a76df634f6da4995b731
Qt version: 5.12.1
jylandry
Postby jylandry » Tue Feb 11, 2020 1:51 am
Seem very similar. Just not sure you cover every cases (To replicate: just create a cube in a new document when in US building).
I also noted an additional problem with the COMBO-view -- Property with 10000 ft.
CASE: -1+1/2" -- If you enter this value in Placement for any object, then look in the combo view-> property: it does display -12.7mm (-1/2 inch). If you re-enter placement, it display -1/2 inch. If you click OK... It still show -12.7mm (-1/2 inch.) So, with this value, the error occur only once.
CASE -10" If you enter -10" in the placement box, it is display as -254mm in combo view->property. And that -10". If you re-enter the placement box. It is still -10" (No problem here)
CASE -10+1/8" If you enter -10+1/8" in the placement box, it is display combo-view property as -250.82mm (-9+7/8")... Re-entering placement display -8+1/8". Clicking OK display 200.02 mm (-7+7/8"). So, error every time IN and OUT. It also seem related to the FRACTION use (The error show with 1/8" fraction).
When you look carefully, it seem an error of interpretation of -10+1/8" -- where it seem interpreted as a formula: -10" + 1/8" = -9"7/8"
CASE -10.125" If you enter -10.125" ... it show correctly in the combo-view-property-placement: -257.8mm (-10+1/8"). When you re-enter the Placement, it does display: -9+7/8" (-250.82mm). so, their is an error when entering the placement box.
If you click OK (without changing anything), you re-enter the same pattern (IN and OUT). 206.38mm (-8+1/8")
CASE: -10'5+3/4" In Placement, if you enter a number -- like -10'5+3/4" that (-3 194.05mm)... if you look at the "mm" displayed in (combo view) "property - Placement" for the object: the value has changed to -2901.95 mm --- that -9'6+1/4". Changing nothing, just re-enter Placement, it display: -8' 5+3/4" (-2 584.45mm)
Again, Changing Nothing, if you click OK, it become: -2292.35 mm (-7'6+1/4") in (combo view) "property - Placement". So, looking at that: Every time you click OK in placement, is does some tampering (in this example, by (+11.5") +292.1mm. Every time you re-enter placement, it does also some tempering by (+12.5") +317.5 mm
CASE -10' This case has no problem: You enter 10'... it remain 10' in Combo-View Property. It also display as 10' if you re-enter placement.
CASE -10'5" You enter 10'5" (3175mm) and it display as 9'7"(2921mm) in combo view-property. When you re-enter placement it show -8'5" (2565.4mm). Then display 2311.4mm( -7'7") in property box.
This time the error is : -254mm (-10") every time you click OK in placement. -355.4mm (-14")
CASE +10000'7" Different problem HERE: 3,048,177.8 mm -- that 10000'7". However, if you look in the Combo-view-property, the conversion display show 10000'7+3/32". When you re-enter the placement panel, everything is fine.
Consequently, this might be or not the same problem. It seem to be a consistent problem with "Fraction" interpretation. It seems also to be a consistent problem with FT'IN" interpretation.
