RichAnno scrambled on SVG export
uwestoehr
Re: RichAnno scrambled on SVG export
Postby uwestoehr » Fri Feb 14, 2020 7:25 pm
wandererfan wrote:
Fri Feb 14, 2020 6:34 pm
At the moment, the choice is between scrambled rich text or plain text. Rich text to Svg isn't on the table.
I don't understand. I mean at least the text size, shape and decoration can be kept in SVG export.
For the frame, I sent you an example of how the SVG must look. What is the issue that such a SVG cannot be created? Maybe I can have a look and find a solution?
wandererfan
Postby wandererfan » Sat Feb 15, 2020 12:41 pm
We don't create the Svg. It comes from Qt functions. The Qt functions don't seem to handle the transformation of RichText in a QTextDocument to Svg in an export file very well.
One solution is to build the Svg ourselves, skip the RTAs when rendering for export, then insert our Svg in the post processing step. This is somewhat similar to how we handle Svg hatch patterns & Templates on export.
If you want to look into this, by all means go ahead.
uwestoehr
Postby uwestoehr » Sat Feb 15, 2020 3:28 pm
I understand. However, can it really not at least keep the text size, font change and decorations? That's in my opinion the minimum we should provide. I mean we offer a rich text feature but you cannot use as such. That is unintuitive.
