FreeCAD command icons in the FC Wiki that should be in SVG format but are in PNG instead
Moderator: agryson
Postby Kunda1 » Fri Feb 07, 2020 4:02 pm
This thread is to track icons in the wiki that should be SVG. Once they have been fixed they will be crossed out.
https://freecadweb.org/wiki/File:Std_Measure_Menu.png
https://freecadweb.org/wiki/Std_Measure_Menu
https://freecadweb.org/wiki/File:Std_ViewCreate.png
https://freecadweb.org/wiki/Arch_MultiMaterial
https://freecadweb.org/wiki/Arch_SetMaterial
https://freecadweb.org/wiki/Arch_CompSetMaterial
https://freecadweb.org/wiki/File:Mesh_RegularSolid.png
https://freecadweb.org/wiki/File:Mesh_H ... ormals.png
https://freecadweb.org/wiki/File:Mesh_F ... veHole.png
https://freecadweb.org/wiki/File:Mesh_ExportMesh.png
https://freecadweb.org/wiki/Part_ReverseShapes
https://freecadweb.org/wiki/Part_ConvertToSolid
https://freecadweb.org/wiki/Part_Export <-- the svg exists but isn't displaying correctly in the {{GuiCommand}} template
https://freecadweb.org/wiki/Part_Import <-- same issue as Export
https://freecadweb.org/wiki/Part_Plane
https://freecadweb.org/wiki/Part_ProjectionOnSurface
https://freecadweb.org/wiki/Part_CompCompoundTools
https://freecadweb.org/wiki/Part_CompSplittingTools
https://freecadweb.org/wiki/Part_CompJoinFeatures
https://freecadweb.org/wiki/File:Part_MakeCompound.png
https://freecadweb.org/wiki/Part_CompOffsetTools
https://freecadweb.org/wiki/Part_Helix
https://freecadweb.org/wiki/Path_FaceProfile
https://freecadweb.org/wiki/File:Part_Prism.png should be Part_Prism.svg (thanks @renatorivo)
https://freecadweb.org/wiki/Path_Array
https://freecadweb.org/wiki/Path_SimpleCopy
https://freecadweb.org/wiki/Path_3DSurface
Re: FreeCAD command icons in the FC Wiki that should be in SVG format but are in PNG instead
Postby Kunda1 » Mon Feb 10, 2020 4:27 pm
Thanks. Crossed-out. Added a few more to OP.
Postby Kunda1 » Fri Feb 14, 2020 5:47 pm
FYI, some of the individual Part CreatePrimitives have SVGs other are PNG
vocx
Postby vocx » Sat Feb 15, 2020 2:54 am
Rename: Part_CreatePrimitives to Part_Primitives
vocx
Postby vocx » Thu Feb 20, 2020 6:17 pm
Kunda1 wrote:
Thu Feb 20, 2020 3:03 pm
What should we do about wiki page icons like...(?)...
https://github.com/FreeCAD/FreeCAD/blob ... #L773-L784
DEF_STD_CMD_ACL(CmdPartCompCompoundTools)
CmdPartCompCompoundTools::CmdPartCompCompoundTools()
  : Command("Part_CompCompoundTools")
    sAppModule      = "Part";
    sGroup          = QT_TR_NOOP("Part");
    sMenuText       = QT_TR_NOOP("Compound tools");
    sToolTipText    = QT_TR_NOOP("Compound tools: working with lists of shapes.");
    sWhatsThis      = "Part_CompCompoundTools";
    sStatusTip      = sToolTipText;
The compound tools don't specify an icon (sPixmap), they use the one first on the list, or the latest command used.
In the wiki I would just use the first icon in the list, and ignore the arrow that Mario added to the PNG icon.
