90° arc becomes 270° when changing dimensions
JiPe38
Postby JiPe38 » Fri Feb 07, 2020 5:42 pm
Hi everybody
I have a design (more or less complicated) in which there is a nylon belt. I use a spreadsheet. To show the interior of the design, I use an "exploding_distance" parameter. When set to 0mm, the assembly of multiple bodies is shown in it's normal configuration. When set to any positive value, it shows the parts exploded.
The attached file, simplified to contain only the belt, contains the value "35 mm" for this explosion parameter. The belt is shown at a position, like extended. No problem. When I set to "0 mm", it can't compute and show the belt in the normal position.
What happens is that, in the sketch, one or two of the arcs, normally 90° angle to joint two lines become 270° angle arcs, which confuses all the sketch and makes it impossible to extrude.
Does this problem come from the way I sketched this belt, or is it a bug ? A strategy to avoid that ?
belt.FCStd
(16.11 KiB) Downloaded 4 times
OS: Windows 10 (10.0)
Version: 0.19.19311 (Git)
Hash: 120b69c74f7dac8c4fa6dbc0a7e10674bde9216c
Python version: 3.7.3
Qt version: 5.12.5
Locale: French/France (fr_FR)
GlouGlou
Re: 90° arc becomes 270° when changing dimensions
Postby GlouGlou » Fri Feb 07, 2020 6:18 pm
maybe like this.
belt.FCStd
(21.49 KiB) Downloaded 6 times
JiPe38
Postby JiPe38 » Fri Feb 07, 2020 8:36 pm
Yes it works. Another way of doing this belt. Thanks.
Is this a known issue ?
Postby chrisb » Sat Feb 08, 2020 9:55 am
Yes. It occurs, because "fully constraint" does not mean "unique". It means only, that there is no smooth (=continuous) transition from one solution to another.
