Buffalo Springfield steam road roller
un1corn
Postby un1corn » Sun Feb 09, 2020 9:48 am
Buffalo Springfield steam road roller Ca 1924 also known as 'Coffee pot'
I put this together around April 2019 took around 4 weeks to complete, quite an interesting model to generate.
Freecad V16 used at that time with Assembly2 WB
Plans from JDW, http://www.vapeuretmodelesavapeur.com/telechargements4/
The assembly file is 17+MB and so is to large to include here.
BS 10.JPG (321.21 KiB) Viewed 1813 times
BS 11.JPG (259.29 KiB) Viewed 1813 times
BS 9.JPG (408.94 KiB) Viewed 1813 times
BS 7.JPG (314.05 KiB) Viewed 1813 times
BS 1.JPG (262.12 KiB) Viewed 1813 times
alberich
Re: Buffalo Springfield steam road roller
Postby alberich » Sun Feb 09, 2020 11:35 am
Fantastic!
Did you use an assembly WB in v0.16?
un1corn
Postby un1corn » Sun Feb 09, 2020 12:09 pm
Yes, as noted above I used Assembly 2 WB
ppemawm
Postby ppemawm » Sun Feb 09, 2020 7:38 pm
Buffalo Springfield steam road roller...
Thanks for sharing another of your awesome models. I know full well how much work has to go into these.
Well done.
Have you ever thought about creating all the bodies in a single file at their proper location in the assembly?
You might enjoy more the in-context "design" process. No assembly workbench required !
"It is a poor workman who blames his tools..." ;)
-alex-
Postby -alex- » Sun Feb 09, 2020 8:02 pm
Very nice model, well done and thanks for sharing!
alberich
Postby alberich » Mon Feb 10, 2020 11:27 am
Heh. I was so fascinated by your images I missed the words. :oops:
mfasano
Postby mfasano » Thu Feb 13, 2020 7:13 pm
I have seen that you are playing with assembly4. How does that compare to creating a model as you describe above?
ppemawm
Postby ppemawm » Fri Feb 14, 2020 2:47 pm
The Assembly4 workbench facilitates the top-down assembly design process wherein all the parts can be created in-context in the same file, typically constrained by an assembly master sketch. The parts are attached to each other using local coordinate systems so that if one must move then the rest follow. The constraints and solver in the master sketch control how the parts move in relation to each other. Top-down design works well for design of original, custom, bespoke, or prototype parts and their assembly.
AFAIK un1corn uses a bottom-up approach wherein parts are created in separate files, imported to an assembly file, and then placed and constrained in their proper position using the A2plus assembly workbench. The assembly constraints and its solver define how the parts react if one or more are moved. Bottom up assembly is useful for predefined parts, reused parts and standard parts such as fasteners, in an assembly arrangement that is known beforehand.
fc_tofu
Postby fc_tofu » Fri Mar 06, 2020 7:16 pm
Thanks.
fc_tofu
Postby fc_tofu » Fri Mar 06, 2020 7:17 pm
Beautiful.
Can you show a TreeView and a dependency graph screenshot?
