Split a window - createViewer(2)
Chri1
Postby Chri1 » Wed Feb 12, 2020 1:09 pm
Hi
For example: I have two cubes (grey, red) and want to draw a line(red) from an vertex of the first cube to a vertex of the second cube.
To do this, I want to split the view into two parts, in the left part should be shown the first cube, in the right part the second cube.
The start of the line should be picked in in the left part, the end of the line in the right part.
Till now I succeeded in creating the two parts:
import FreeCADGui
from pivy import coin
from PySide import QtCore,QtGui
import os,re
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
v = FreeCADGui.createViewer(2, "NEU")
vv0 = v.getViewer(0)
vv1 = v.getViewer(1)
vv0.setSceneGraph(sg)
vv1.setSceneGraph(sg)
Now I can zoom by the mouse-wheel,and - different to the original window - move/rotate the view by right mouse with Shift/Strg
But when I try to draw the line (from left-window to right-window), the line is drawn somewhere and the snaps of the cubes do not work
Also it would be nice, if while drawing, a line is shown over both parts from starpoint to Cursor (see green line)
Thanks
Chri1
edi
Re: Split a window - createViewer(2)
Postby edi » Wed Feb 12, 2020 2:24 pm
Hello Chri1
I think your problem is the following: In FreeCAD each object exists twice, as App.ActiveDocument and as Gui.ActiveDocument.
Your macro creates a new Gui object, which is not or not correct connected to the App object.
When starting the macro the new splited window "NEU" opens, and shows the object.
The old window of the object keeps existing. If you close the old window, the object in window "NEU" disappears.
I think the solution of your problem is to connect the Gui.ActiveDocument to the new opened split window.
