Choose a more precise object name: vonMises instead of StressValues
UR_
Postby UR_ » Thu Feb 13, 2020 10:02 am
Disturbed for a long time by diffuse object naming, like
Screenshot 002.png (8.09 KiB) Viewed 350 times
instead of "von Mises equivalent stress".
There are many stress definitions out there, e.g. von Mises, Tresca, Coulomb, Saint-Venant, Guest, Rankine, Burzyński-Yagn, Huber, Mao-Hong Yu, Altenbach-Bolchoun-Kolupaev
(some of them from wikipedia, and unkown for myself :roll: )
But we should try (at least) to be more precise in naming.
Branch can be found here: https://github.com/UR-0/FreeCAD/commit/ ... 66b165d015
But there is of a drawback. Oldstyle result objects have to be reloaded or recalculated.
What to you think about this?
HarryvL
Re: Choose a more precise object name: vonMises instead of StressValues
Postby HarryvL » Thu Feb 13, 2020 12:17 pm
+1
bernd
Postby bernd » Fri Feb 14, 2020 3:58 pm
git commit 8b68ab7 hopefully no regression somewhere. I had not have the time to test befor merge ... Nevermind we will fix any regression.
The result objects of the start wb examples needs to be updated ... !
bernd
Postby bernd » Fri Feb 14, 2020 4:02 pm
Ahh forgot to say it's a valuable change !
vocx
Postby vocx » Fri Feb 14, 2020 4:10 pm
git commit 8b68ab7 hopefully no regression somewhere...
I'm not opposed to the change, but doesn't this break the Results object? You cannot just rename a property like that because you won't be able to load the "StressValues" property from older files. Is that not a problem?
To avoid breaking older files, I think we should migrate the property through some code inside onDocumentRestored. This is mentioned in this thread, Migrating and upgrading old scripted objects.
UR_
Postby UR_ » Fri Feb 14, 2020 8:07 pm
Yes, old result objects get broken.
bernd wrote: :bell:
To patch old result object we need to add to femobjects\_FemResultMechanical.py line 304:
    def onDocumentRestored(self, obj):
        if hasattr(obj, "StressValues") == True:
            obj.addProperty(
                "App::PropertyFloatList",
                "vonMises",
                "NodeData",
                True
            obj.vonMises = obj.StressValues
            obj.removeProperty("StressValues")
Should this really be done, or is this to much effort.
IIRC, result and other objects gets broken on regular bases in past ;)
vocx
Postby vocx » Sat Feb 15, 2020 7:03 am
I think in FEM it's not very critical to break the result object because if the problem is well defined, the user can just re-run the solver to obtain the results again. Still, it's just a small thing to consider.
In other workbenches it's possibly more important to maintain compatibility and be able to access and re-edit the older objects.
UR_
Postby UR_ » Sat Feb 15, 2020 9:15 am
I think in FEM it's not very critical to break ...
Nevertheless, PR: https://github.com/FreeCAD/FreeCAD/pull/3052
bernd
Postby bernd » Sat Feb 15, 2020 11:27 am
git commit f192ac8 great. We should have started whith such migrate code much earlier.
