Which FEM Analysis Icon is the one we use ?
vocx
Re: Which FEM Analysis Icon is the one we use ?
Postby vocx » Sat Feb 15, 2020 1:27 am
In the source code, the file is called "fem-analysis.svg".
In the wiki all pages should start with a capital letter, so the wiki calls this file, "Fem-analysis.svg".
The icon "Fem_Analysis.svg" looks a bit bigger, and the color is a bit darker. Moreover, this icon is only used in what appears to be a test page by quick61 from 2014, Artwork_quick61_rework.
Therefore, I think the second of the icons that you present can be removed.
bernd
Postby bernd » Sat Feb 15, 2020 6:36 am
wait! The second one looks much better! I will have a look. Icons in FEM where renamed a few times.
bernd
Postby bernd » Sat Feb 15, 2020 11:52 am
It is the opposite! The second one is the one which is used in source code and which is therefor used in FreeCAD software. This should stay as it is in the wiki! https://github.com/FreeCAD/FreeCAD/blob ... alysis.svg
Postby Kunda1 » Sat Feb 15, 2020 1:11 pm
:+1:
I'll remove the 1st icon then and re-name the link on the pages that use it.
bernd
Postby bernd » Sat Feb 15, 2020 3:38 pm
great
vocx
Postby vocx » Sat Feb 15, 2020 3:53 pm
... It is the opposite! The second one is the one which is used in source code ...
Well, I was talking about the page name, as that is what matters in the wiki.
The page "Fem-analysis.svg" should be kept. Of course, its content can be updated with the actual icon used in the source code but that's a trivial step.
Postby Kunda1 » Sun Feb 16, 2020 12:57 pm
Can we rename it in the source code then?
So it's all uniform ?
Aren't other icons using snake_case ?
vocx
Postby vocx » Sun Feb 16, 2020 4:44 pm
There is nothing standard in FreeCAD, in general. This is the reason we need to improve standardization across different workbenches.
In FEM, icons are like this.
ls -1 src/Mod/Fem/Gui/Resources/icons/
Arch_Material_Group.svg
fem-add-fem-mesh.svg
fem-add-material.svg
fem-add-part.svg
fem-analysis.svg
fem-clipping-plane-add.svg
fem-clipping-plane-remove-all.svg
fem-constraint-bearing.svg
fem-constraint-contact.svg
fem-constraint-displacement.svg
fem-constraint-electrostatic-potential.svg
fem-constraint-fixed.svg
fem-constraint-flow-velocity.svg
fem-constraint-fluid-boundary.svg
fem-constraint-force.svg
fem-constraint-gear.svg
fem-constraint-heatflux.svg
fem-constraint-initial-flow-velocity.svg
fem-constraint-initial-temperature.svg
fem-constraint-planerotation.svg
fem-constraint-pressure.svg
fem-constraint-pulley.svg
fem-constraint-selfweight.svg
fem-constraint-temperature.svg
fem-constraint-transform.svg
fem-element-fluid-1d.svg
fem-element-geometry-1d.svg
fem-element-geometry-2d.svg
fem-element-rotation-1d.svg
fem-equation-elasticity.svg
fem-equation-electrostatic.svg
fem-equation-flow.svg
fem-equation-fluxsolver.svg
fem-equation-heat.svg
fem-femmesh-boundary-layer.svg
fem-femmesh-clear-mesh.svg
fem-femmesh-create-node-by-poly.svg
fem-femmesh-from-shape.svg
fem-femmesh-gmsh-from-shape.svg
fem-femmesh-netgen-from-shape.svg
fem-femmesh-print-info.svg
fem-femmesh-region.svg
fem-femmesh-result.svg
fem-femmesh-to-mesh.svg
fem-material-fluid.svg
fem-material-nonlinear.svg
fem-material-reinforced.svg
fem-material.svg
fem-post-data-pipline.svg
fem-post-filter-clip-region.svg
fem-post-filter-clip-scalar.svg
fem-post-filter-cut-function.svg
fem-post-filter-data-along-line.svg
fem-post-filter-data-at-point.svg
fem-post-filter-linearized-stresses.svg
fem-post-filter-warp.svg
fem-post-geo-box.svg
fem-post-geo-cylinder.svg
fem-post-geo-isosurface.svg
fem-post-geo-plane.svg
fem-post-geo-sphere.svg
fem-post-result-show.svg
fem-post-results-purge.svg
fem-solver-analysis-frequency.svg
fem-solver-analysis-static.svg
fem-solver-analysis-thermomechanical.svg
fem-solver-control.svg
fem-solver-elmer.svg
fem-solver-inp-editor.svg
fem-solver-run.svg
fem-solver-standard.svg
FemWorkbench.svg
preferences-fem.svg
I believe TechDraw used to have a similar style; that was until Uwe made a pull request to rename a bunch of files and fix the source code. It can be done, but it's hard work.
Postby Kunda1 » Tue Feb 18, 2020 2:57 pm
Is this a project that someone int the FEM community would be able to tackle before the upcoming release in April ? It would be very good to uniform the documentation as best as possible before that.
